Server Version#: 1.18.8.2527
I’m running server version: 1.18.8.2527, in docker on unraid 6.8.2. It seems almost daily the plex server becomes unresponsive. It doesn’t respond from any device on the lan or wan. Everything else on the unraid server is fine, and other docker containers continue working without issue. Plex-Logs.zip (4.1 MB) Restarting the docker container always resolves the issue. When it was unresponsive I zipped up the logs and they are attached. If someone can read them and figure out why it seems to be crashing so frequently. I’ve also attached the crash dump incase that’s helpful. Crash-Report.zip (48.5 KB)
