Server Version#: 1.32.4.7195
The last 2 or 3 updates have resulted in the “LocalAppDataPath” registry key being deleted and Plex basically being defaulted back to it’s initial install state with no libraries or content. I have to manually add the key back into the registry and restart.
Will this happen from now on? I don’t see why this key should be removed as they took away the ability to make this change in the UI so the only way to make this happen is directly in the registry.
