Server Version#:4.0
Good morning,
can anyone help me figure out how to update Plex via omv?
Moreover, I wanted to know the differences with the installation of the Docker app!
Is there any guide on this?
Should I use the Docker?
The OMV user forum is full of guides for setting up dockers, including Plex.
The typical procedure to update Plex via docker is to first chose the proper image tag when installing the docker, and then to just restart the container when an update is available.
I suggest using the docker instead of the OMV Plex plugin. But I have a dozen or so dockers running here and running one more or one less doesn’t make a difference in my setting.
Thank you for your answer.
I will look for a guide suited to my needs, I am a neophyte and I searched for different guides also on youtube, but without being able to fully understand the mechanism.
