Hi… first post, reasonably new user to Plex but I’ve been a long time user of Emby (almost 10yrs in fact since the days when it was called video browser and nothing more than a windows Vista media server plugin).
My problem lies with the storage of metadata… I have a very, very large collection of media. Close to 2000 movies, 15000+ tv episodes and 30,000+ audio files. The metadata for all of this is a huge strain on resources.
now I’ve always stored my metadata locally in the source folder for each item… this means data is spread around across multiple drives and easily accessed and can be manually altered if needed (neither emby nor plex seems to get it all right, even though file structure/naming is perfect for everything I own).
But the biggest issue is that whilst emby allows this, even though it seems to then store some in it’s own DB… plex does not. So it’s creating a whole new set of data in it’s own DB.
I’ve just checked and emby plus it’s W7 media centre plugin uses some 33GB of storage, Plex is using some 16GB additional storage… and NONE of this includes the local metadata/image storage for each individual item. I can only take a wild guess at how much extra storage space is wasted across 6 more drives in my media server.
So why can’t Plex (or emby) use that locally stored data instead of ignoring it and using yet more storage space on my SSD… Which isn’t a large one.
I can see why I’ve seen so many people with problems using the server software on smaller devices like the nvidia shield… in my opinion they’re not fit for the task… but fine for accessing a proper server and streaming/direct playing of media… Does that make me a server snob… lol… possibly. I put a lot of time, effort and money into my setup… it gets a total rebuild every 3-4yrs along with at least a couple of new/larger drives every year… But with the 18TB of media I currently have… it needs to be capable.
I like Plex… I like Emby… I’m currently running both side by side and evaluating the pros/cons of both as I’ve seen some serious loss of focus with Emby that have made it a far less enjoyable experience… Areas where plex shines much brighter… and then I find areas where Plex falls over and Emby shines. Seems neither one is the complete package.
Emby seems to be far more hungry in terms of space requirements for metadata than Plex… Why emby needs to store an extra 10GB of data just for the media centre plugin baffles the crap out of me… but then a lot of the bad design choices being made by the devs is making it an unpleasant experience on some devices. plex on android for TV’s is far superior, but the number of services running for Plex and the amount of CPU cycles being used is vastly higher than Emby… transcoding high bitrate HEVC video files is a real struggle for plex even on a quad core 4.2ghz CPU with 8GB ram and Plex seems incapable of stopping itself from running over services whilst it’s transcoding… leading to stuttering and loss of connection. Something that Emby never does.
I’ve gone through settings and if there’s anything that can be suggested to reduce the amount of storage needed for metadata… I’d appreciate it… But I’d love it even more if it was able to use what’s already there and not even NEED to store it within it’s own DB at all. As it stands I’ve got multiple copies of the same data and with Plex have no idea what’s stored where and cannot manually edit the metadata files when it fails to get it right and when trying to correct it within the browser UI fails to work (I can at least do that with Emby).
I have a lifetime sub to Emby, been a supporter for many years… used to help out with testing until a few years ago… I’ve paid for the android app for Plex… but at the moment I see nothing that makes me want to buy a subscription to the Full plex package. It’s good… but it’s not great enough yet… Emby is also good… but is fast becoming a badly designed mess with bad design choices after bad design choices… Like trying to force the browser UI to work in the same way as it does on a touch screen… which makes the process of finding and accessing media 10 times more time consuming. Sadly those in charge have a completely blinkered view of things and cannot see the damage they’re doing… It’s damage that’s seen me start to test alternatives to it after 9+yrs.
So good job so far… as I find issues I’ll mention them and I’m always willing to offer suggestions… If emby took a few design tips from you lot (your browser UI is so much better than the mess theirs has become)… it’d be game over for me. But I use the browser UI a lot from my office, so yours appeals greatly to me over emby… But at home I use W7 media server a lot too, and the plugin for that is very nice indeed… Shame you haven’t got something to compete with that… Because using emby with my MC remote makes everything so smooth and easy to use… and it’s why 2 of my machines hooked up to TV will NEVER be upgraded from W7… simply because losing the use of those remotes isn’t an option and there’s nothing out there that allows me to use them with anything else on any other OS that I know of… But if you know of anything that allows me to start it from the green button and control everything from it please let me know… I may be a bit behind the latest tech as my last rebuild was 2yrs ago… waiting on the new AM4 stuff from AMD in 2nd quarter before I evaluate if it’s good enough for a rebuild of my gaming rig.
