In the changelog (http://forums.plex.tv/discussion/comment/1378615/#Comment_1378615) for the Plex Web Player 3.0.0, it is written that there is now support for iMDB and Rotten Tomatoes ratings.
Going through the PMS settings, I can’t seem to find where to enable this at.
Any help will be appriciated
your movies must be matched using the ‘Plex Movie’ agent
post a Plex XML info of one of your movies and I tell you if that is the case
the properties of the Plex Movie agent must be set so it fetches RT ratings.
If the movie is already matched and you’ve set the properties like shown above, a Refresh should fetch the RT ratings.
Note: not all movies will get a RT rating. Some will fall back to an IMDb rating.
