Hi There,
On removing a Plex server manually from Plex Web (or maybe it removed itself after a prolonged period of inactivity?), it appears that the “sharing N libraries with this friend” message (in Plex Web -> Settings -> Users -> Friends) is not updated to remove the number of libraries that were originally shared with this friend on the old / removed server?
For example, if I had 2 Plex Servers running previously and shared 2 libraries from Server 1 and 3 libraries from Server 2 with a Friend, it correctly states that “sharing 5 libraries with this friend”… but if I remove Server 1 (as in remove it from Plex Web completely without unsharing the shared libraries with this friend first) it still seems to state “sharing 5 libraries with this friend” when it should state “sharing 3 libraries with this friend” (i.e. now only sharing the 3 libraries from Server 2)?
There doesn’t seem to be any way to remove the shared library count from the old removed Server 1 since it no longer appears when you try to edit the friend’s shared libraries (expected since Server 1 has been removed)?
… Also, this doesn’t seem to happen with every friend - It seems to happen randomly?
