Plex Web will not play some MKVs
When trying to play the files in question via Plex Web the spinner just spins and nothing happens, no errors and no timeouts.
All of the files that will not play are similar to the below with the same codecs, resolutions, and similar bitrates. They will not play in any browser (Firefox, Edge, Chrome) on both Windows and Linux either using direct play or transcoding but they do play fine on the Windows Plex App and also play on Firestick and Android. They also play fine on various other media players like VLC. Also, I know that some if these files have played previously using the plex web client with no problem as I was re-watching a series when the issue started.
Server Version#: 1.32.8.7639
Player Version#: Plex Web version 4.116.1
Example File File Details:
Media
Duration 19:43
Bitrate 5259 kbps
Width 1280
Height 720
Aspect Ratio 1.78
Video Resolution 720p
Container MKV
Video Frame Rate 24p
Video Profile high
Part
Duration 19:43
Size 742.22 MB
Container MKV
Has Thumbnail 1
Video Profile high
Codec H264
Bitrate 4618 kbps
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Coded Height 720
Coded Width 1280
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 23.976 fps
Height 720
Level 3.1
Profile high
Ref Frames 4
Scan Type progressive
Width 1280
Display Title 720p (H.264)
Extended Display Title 720p (H.264)
Codec EAC3
Channels 6
Bitrate 640 kbps
Language English
Language Tag en
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Display Title English (EAC3 5.1)
Extended Display Title English (EAC3 5.1)
Codec SRT
Language English
Language Tag en
Display Title English (SRT)
Extended Display Title English (SRT)
Codec SRT
Language English
Language Tag en
Hearing Impaired true
Title SDH
Display Title English SDH (SRT)
Extended Display Title SDH (English SRT)
Debug Logs
“type”: “info”,
“host”: “192.168.1.50:32400”,
“userAgent”: “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/115.0”,
“browser”: {
“platformVersion”: “10”,
“id”: “firefox”,
“name”: “Firefox”,
“version”: “115.0”,
“gecko”: true,
“platform”: “Windows”,
“platformID”: “windows”,
“platformModifierKey”: “ctrl”
“version”: “4.116.1”,
“primaryServerUrl”: “http://192.168.1.50:32400/”,
“primaryServerAuthToken”: true,
“username”: “MightyMouth”,
“cloudUrl”: [
“scheme”: “https”,
“address”: “clients.plex.tv”,
“uri”: “https://clients.plex.tv”,
“testState”: “connected”,
“isBundled”: false,
“isFallback”: false,
“relay”: false,
“isUntested”: false,
“isPending”: false,
“isConnected”: true,
“isUnauthorized”: false,
“isUnavailable”: false,
“isFailed”: false,
“isAborted”: false,
“isLoopback”: false,
“isPrivate”: false,
“isHttps”: true,
“isSecure”: true,
“isPlexDirect”: false,
“currentTest”: null,
“sources”: [
“id”: “internal”
Also in the console I am seeing the following
Likely the same cause as this user’s issue: TrueHD audio transcoding BUG = error not enough space - #2 by OttoKerner
