Server Version#: 1.32.4.7195
Player Version#: (plex web with same version)
I am running Plex off a MyCloud EX2 Ultra. As of yesterday, whenever I attempt to play any MKV file through the web player on a MacBook Air (M1/16 gig ram, late 2021), I get the message " Playback Error - This server is not powerful enough to convert video." However it doesn’t seem that this can be an issue with transcode power, as when I attempt to view the same files on any other device on my LAN - iOS, AppleTV, Roku, etc - playback works without issue. Only the web player is returning this error.
I cannot say with certainty at what point MKV playback stopped, but it appears to have been a problem at least as of version 1.32.4.7195.
Please advise. Thanks!
EDIT TO ADD: I just attempted to play an MKV file in the Plex app on the same computer, and it worked without issue. So whatever is happening here seems to be specific to the web player itself.
an MKV is also just a container. the types of video/audio/subtitles codecs inside are generally more important info in deciding if something is transcoding or not.
I have transcoding turned off at the server level, so I wouldn’t expect it…but the larger point is that I wasn’t having this issue until just recently, and as far as I know I haven’t changed any settings that would impact it.
I would turn transcoding back on play the file and see why it needs transcode. If you turned off video transcoding then it is likely something to do with video stream/codec of file. A web browser cannot play very much natively
I unchecked “disable video stream transcoding” and tried again. I got a black screen for about 30 seconds, about 13 seconds of playback, and then it appeared to freeze, while I assume it was doing more transcoding. I’m not sure how to determine “why it needs to transcode”.
I agree - that’s why I had transcoding turned off.
The VP9 file is a new one, in fairness. While the MPEG2 file is technically new, it was created from MakeMKV using it’s default settings, and I’ve played other files derived that way in the past without issue.
