Plex will NOT load on Xbox 360
I’ve been experiencing this problem for the past few weeks. I’ve already deleted the app, cleared the cache, re-downloaded, re-signed in with another PIN, and it just keeps searching. Is there something going on right now?
Thanks!
I am also using a 360 and all is fine. Try to login over your user/password. I saw somtimes problems with this Pin-Login.
If you prefere the Pin, log into your Account on the Plex Website and put the pin in per hand.
