insom
January 7, 2012, 1:22pm
1
Hi all.
I have built a media box using a combination of Plex, Wine1.3, Lubuntu. Everything is generally fine, and works like a dream, exc attept 1 thing. Getting skins to work.
I have tried a number of skins, and all are having the same effect apart from the default skin. Plex loads to the menu, go into any sub-menu, and the software crashes. The only way to get it working properly again, is to remove the skin’s folder and restart Plex.
I am not sure where the problem lies with this, whether it is Plex, Wine, Linux or any combination of. I have tried the skins in Windows with no problems.
I have attached the log file generated by PMC in case anyone has any suggestions
13:11:19 T:36 M: 6% NOTICE: -----------------------------------------------------------------------
13:11:19 T:36 M: 6% NOTICE: Starting Plex 0.9.5.2, Platform: Windows Server 2008 R2, 32-bit Service Pack 1 build 7601. Built on Nov 28 2011 (Git:06ca164, compiler VC++ 1600)
13:11:19 T:36 M: 6% NOTICE: Intel(R) Pentium(R) 4 CPU 2.40GHz
13:11:19 T:36 M: 6% NOTICE: Desktop Resolution: 1280x800 32Bit at 60Hz
13:11:19 T:36 M: 6% NOTICE: Running with administrator rights
13:11:19 T:36 M: 6% NOTICE: special://xbmc/ is mapped to: C:\Program Files\Plex\Plex Media Center
13:11:19 T:36 M: 6% NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\Plex\Plex Media Center
13:11:19 T:36 M: 6% NOTICE: special://masterprofile/ is mapped to: C:\users\plex\Local Settings\Application Data\Plex\userdata
13:11:19 T:36 M: 6% NOTICE: special://home/ is mapped to: C:\users\plex\Local Settings\Application Data\Plex
13:11:19 T:36 M: 6% NOTICE: special://temp/ is mapped to: C:\users\plex\Local Settings\Application Data\Plex\cache
13:11:19 T:36 M: 6% NOTICE: The executable running is: C:\Program Files\Plex\Plex Media Center\Plex.exe
13:11:19 T:36 M: 6% NOTICE: Log File is located: C:\users\plex\Local Settings\Application Data\Plex\Plex.log
13:11:19 T:36 M: 6% NOTICE: Setup SDL
13:11:19 T:36 M: 6% NOTICE: Found screen: X11 Windowing System on X11 Windowing System, adapter 0.
13:11:19 T:36 M: 6% NOTICE: Primary mode: 1280x800 @ 60.00 - Full Screen
13:11:19 T:36 M: 6% NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
13:11:19 T:36 M: 6% NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
13:11:19 T:36 M: 6% NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
13:11:19 T:36 M: 6% NOTICE: Additional mode: 800x600 @ 56.00 - Full Screen
13:11:19 T:36 M: 6% NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
13:11:19 T:36 M: 6% NOTICE: load settings...
13:11:19 T:36 M: 6% NOTICE: special://profile/ is mapped to: special://masterprofile/
13:11:19 T:36 M: 6% NOTICE: loading special://masterprofile/guisettings.xml
13:11:19 T:36 M: 6% NOTICE: Getting hardware information now...
13:11:19 T:36 M: 6% NOTICE: Checking resolution 12
13:11:19 T:36 M: 6% NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:11:19 T:36 M: 6% NOTICE: Loaded playercorefactory configuration
13:11:19 T:36 M: 6% NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:11:19 T:36 M: 6% NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:11:19 T:36 M: 6% NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
13:11:19 T:36 M: 6% NOTICE: Default DVD Player: dvdplayer
13:11:19 T:36 M: 6% NOTICE: Default Video Player: dvdplayer
13:11:19 T:36 M: 6% NOTICE: Default Audio Player: paplayer
13:11:19 T:36 M: 6% NOTICE: Loading media sources from special://masterprofile/sources.xml
13:11:19 T:42 M: 6% NOTICE: Plex Source Scanner starting...(127.0.0.1) (uuid: 4248d31ecf3a50b88a1a9730dd8b1946066405f6)
13:11:19 T:42 M: 6% NOTICE: Scanning remote server: 127.0.0.1 (remote: 0)
13:11:19 T:42 M: 6% NOTICE: PlexDirectory::GetDirectory(http://127.0.0.1:32400/music)
13:11:19 T:42 M: 6% NOTICE: PlexDirectory::GetDirectory(http://127.0.0.1:32400/video)
13:11:19 T:42 M: 6% NOTICE: PlexDirectory::GetDirectory(http://127.0.0.1:32400/photos)
13:11:19 T:42 M: 6% NOTICE: PlexDirectory::GetDirectory(http://127.0.0.1:32400/applications)
13:11:19 T:42 M: 6% NOTICE: PlexDirectory::GetDirectory(http://127.0.0.1:32400/library/sections)
13:11:19 T:42 M: 6% NOTICE: Scanning host 127.0.0.1 is complete.
13:11:19 T:42 M: 6% NOTICE: Plex Source Scanner finished for host 127.0.0.1 (0 left)
13:11:20 T:36 M: 7% NOTICE: initializing playlistplayer
13:11:20 T:36 M: 7% NOTICE: DONE initializing playlistplayer
13:11:20 T:36 M: 7% ERROR: Couldn't load font name: MediaPreviewDetailsHeader(HelveticaNeue), trying to substitute arial.ttf
13:11:20 T:36 M: 7% ERROR: Couldn't load font name: LargeSearchFont(HelveticaNeue), trying to substitute arial.ttf
13:11:20 T:36 M: 7% ERROR: Couldn't load font name: MediumSearchFont(HelveticaNeue), trying to substitute arial.ttf
13:11:20 T:36 M: 7% ERROR: Couldn't load font name: SearchResult(HelveticaNeue), trying to substitute arial.ttf
13:11:20 T:36 M: 7% ERROR: Couldn't load font name: SearchResultSmaller(HelveticaNeue), trying to substitute arial.ttf
13:11:20 T:36 M: 7% ERROR: Couldn't load font name: SearchResultSmall(HelveticaNeue), trying to substitute arial.ttf
13:11:20 T:36 M: 7% ERROR: Couldn't load font name: info2(HelveticaNeue), trying to substitute arial.ttf
13:11:20 T:36 M: 7% ERROR: unable to load:C:\Program Files\Plex\Plex Media Center\addons\skin.blur-316020d\720p\DialogSeekBar.xml, Line 0
Error document empty.
13:11:20 T:36 M: 7% WARNING: Skin has invalid include: fadeinout
13:11:21 T:36 M: 8% WARNING: Previous line repeats 1 times.
13:11:21 T:36 M: 8% NOTICE: initialize done
13:11:21 T:36 M: 8% NOTICE: Running the application...
13:11:21 T:36 M: 8% NOTICE: Webserver: Starting...
13:11:21 T:36 M: 8% NOTICE: WebServer: Started the webserver
13:11:21 T:36 M: 8% NOTICE: ES: Starting event server
13:11:21 T:54 M: 8% NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
13:11:21 T:54 M: 8% NOTICE: UDP: Listening on port 9777
13:11:27 T:54 M: 8% ERROR: SOCK: Error selecting socket(s)
13:11:27 T:54 M: 8% ERROR: ES: Exception caught while listening for socket
13:11:27 T:54 M: 8% NOTICE: ES: UDP Event server stopped
13:11:27 T:55 M: 8% ERROR: JSONRPC Server: Select failed
13:11:28 T:54 M: 8% NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
13:11:28 T:54 M: 8% NOTICE: UDP: Listening on port 9777
13:11:29 T:40 M: 8% NOTICE: PlexDirectory::GetDirectory(http://127.0.0.1:32400)
Any suggestions would be appreciated.
Insom
system
Closed
December 20, 2019, 9:35pm
2
