Server Version#:1.13.8.5395
Player Version#:N/A
Sep 25, 2018 02:04:27.186 [0x80a008000] INFO - Plex Media Server v1.13.8.5395-10d48da0d - FreeBSD PC amd64 - build: freebsd-x86_64 freebsd - GMT 10:00
Sep 25, 2018 02:04:27.186 [0x80a008000] ERROR - Failed to determine system locale: locale::facet::_S_create_c_locale name not valid. Defaulting to en-US.
Sep 25, 2018 02:04:27.186 [0x80a008000] INFO - FreeBSD version: 9.3-RELEASE (FreeBSD 9.3-RELEASE-p43 #0: Sat May 28 00:19:32 UTC 2016 root@amd64-builder.daemonology.net:/usr/obj/usr/src/sys/GENERIC), language: en-US
Sep 25, 2018 02:04:27.186 [0x80a008000] INFO - Processor Intel® Xeon® CPU E3-1230 V2 @ 3.30GHz
Sep 25, 2018 02:04:27.186 [0x80a008000] INFO - /usr/local/share/plexmediaserver-plexpass/Plex_Media_Server
Sep 25, 2018 02:04:27.184 [0x80a007400] WARN - Default locale is invalid; falling back on classic+UTF-8
Sep 25, 2018 02:04:27.186 [0x80a007400] DEBUG - BPQ: [Idle] -> [Starting]
Sep 25, 2018 02:04:27.187 [0x80a007400] ERROR - Unable to open named mutex 9334581e-7251-4ef7-a8ec-5bfe8e89ff68 with option 1: File exists
Sep 25, 2018 02:04:27.187 [0x80a007400] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.13.0, threadsafe=1
Sep 25, 2018 02:04:27.187 [0x80a007400] DEBUG - Installing Library Database from ["/usr/local/share/plexmediaserver-plexpass/Resources/com.plexapp.plugins.library.db"] to ["/usr/local/plexdata-plexpass/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db"]
Sep 25, 2018 02:04:27.190 [0x80a007400] ERROR - SQLITE3:0x10, 8, statement aborts at 1: [PRAGMA journal_mode=WAL] attempt to write a readonly database
Sep 25, 2018 02:04:27.190 [0x80a007400] ERROR - Database corruption: sqlite3_statement_backend::loadOne: attempt to write a readonly database
Sep 25, 2018 02:04:27.191 [0x80a007400] ERROR - Error: Unable to set up server: sqlite3_statement_backend::loadOne: attempt to write a readonly database (N4soci10soci_errorE)
Tried removing /usr/local/plexdata* and reinstalling etc… just won’t start … have another server identical except for the CPU and motherboard (same OS/Version/Patch level etc) and it’s working fine…
