Windows 10 have tried regedit removal revo uninstaller etc, still asking for shutdown-msi missing
Please help
Please help
have you tried the Microsoft fix it tool linked on this page https://support.plex.tv/hc/en-us/articles/202967086-Windows-Errors-trying-to-upgrade-install-or-uninstall-Plex-Media-Server
Yes tried that also,
Done this also, its weird. Because nothing else in my system is failing
Good morning
Tried edge, same problem
I really dont want to bork my system since its running other stuff to
nope get same message
C:\ProgramData\Package Cache{E9F87862-A401-4B60-8F85-66C77E21F458}v1.7.3878\pms-shutdown.msi
Btw: it is plex pass version Plex-Media-Server-1.7.2.3878-8088811b8 im trying to install
Probably a new one after i tried to remove all traces of plex in regestry and files and folders
Removed all visual c,
sfc /scannow did not find any faults
Restert did not do anything
Getting frustrated
What version did you have installed before trying to upgrade?
Sorry, every trace is removed from regestry, still same issue msi not a valid blahblah
Hi again removed all traces of plex again and checked files downloaded with Hastab, it is all fine
Weird stuff. Never seen a installer behave like this
now i removed all traces of microsoft visual c (uninstalled) then delete all reg keys.
Meybe now my system goes to hell next restart
Do you have any anti-virus or malware/etc monitoring programs running?
I only ask because the message you are receiving may also include running said MSI and returning an exit code.
[2EA4:21FC][2017-06-17T22:12:40]i001: Burn v3.10.3.3007, Windows v10.0 (Build 14393: Service Pack 0), path: C:\Users\MATRIX~1\AppData\Local\Temp{60FB131A-55C2-42F5-8C94-4CCFB8485573}.cr\Plex-Media-Server-1.5.6.3790-4613ce077.exe
[2EA4:21FC][2017-06-17T22:12:40]i000: Initializing string variable ‘OEM’ to value ‘’
[2EA4:21FC][2017-06-17T22:12:40]i000: Initializing string variable ‘NOLAUNCH’ to value ‘’
[2EA4:21FC][2017-06-17T22:12:40]i000: Initializing string variable ‘InstallFolder’ to value ‘[ProgramFilesFolder]Plex\Plex Media Server’
[2EA4:21FC][2017-06-17T22:12:40]i000: Initializing string variable ‘LaunchTarget’ to value ‘[InstallFolder]\Plex Media Server.exe’
[2EA4:21FC][2017-06-17T22:12:40]i009: Command Line: ‘-burn.clean.room=C:\Users\Matrixserver\Downloads\Plex-Media-Server-1.5.6.3790-4613ce077.exe -burn.filehandle.attached=544 -burn.filehandle.self=548’
[2EA4:21FC][2017-06-17T22:12:40]i000: Setting string variable ‘WixBundleOriginalSource’ to value ‘C:\Users\Matrixserver\Downloads\Plex-Media-Server-1.5.6.3790-4613ce077.exe’
[2EA4:21FC][2017-06-17T22:12:40]i000: Setting string variable ‘WixBundleOriginalSourceFolder’ to value ‘C:\Users\Matrixserver\Downloads’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WixBundleLog’ to value ‘C:\Users\MATRIX~1\AppData\Local\Temp\Plex Media Server_20170617221241.log’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WixBundleName’ to value ‘Plex Media Server’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WixBundleManufacturer’ to value ‘Plex, Inc.’
[2EA4:0FB0][2017-06-17T22:12:41]i000: Setting numeric variable ‘WixStdBALanguageId’ to value 1033
[2EA4:0FB0][2017-06-17T22:12:41]i000: Setting version variable ‘WixBundleFileVersion’ to value ‘1.5.6.3790’
[2EA4:21FC][2017-06-17T22:12:41]i100: Detect begin, 16 packages
[2EA4:21FC][2017-06-17T22:12:41]i000: Registry key not found. Key = ‘Software\Plex, Inc.\Plex Media Server’
[2EA4:21FC][2017-06-17T22:12:41]i052: Condition ‘NOT PreviousInstallFolder’ evaluates to true.
[2EA4:21FC][2017-06-17T22:12:41]i052: Condition ‘PreviousInstallFolder’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting numeric variable ‘FoundMfPlatDll’ to value 1
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting numeric variable ‘Found_ucrtbase_dll’ to value 1
[2EA4:21FC][2017-06-17T22:12:41]i052: Condition ‘NOT Found_ucrtbase_dll’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:41]i000: Registry key not found. Key = ‘SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2919355~31bf3856ad364e35~amd646.3.1.14’6.3.1.14’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WinRegReleaseID’ to value ‘1607’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WinRegCurrentBuildNumber’ to value ‘14393’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WinRegInstallationType’ to value ‘Client’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WinRegEditionID’ to value ‘ProfessionalN’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WinRegProductName’ to value ‘Windows 10 Pro N’
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WinRegMediaPlayer’ to value ‘%ProgramFiles%\Windows Media Player’
[2EA4:21FC][2017-06-17T22:12:41]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB2919355~31bf3856ad364e35~x86
[2EA4:21FC][2017-06-17T22:12:41]i000: Setting string variable ‘WinRegCurrentBuild’ to value ‘14393’
[2EA4:21FC][2017-06-17T22:12:41]i052: Condition ‘FoundMfPlatDll’ evaluates to true.
[2EA4:21FC][2017-06-17T22:12:41]i052: Condition ‘FoundMfPlatDll AND WinRegMediaPlayer’ evaluates to true.
[2EA4:21FC][2017-06-17T22:12:41]i103: Detected related package: {F935BB29-E095-46A3-8936-965397627AA0}, scope: PerMachine, version: 1.4.3495.0, language: 0 operation: MajorUpgrade
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin7x86, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin7x64, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin8x86, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin8x64, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin81x86, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin81x64, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin10x86, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin10x64, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin10x861511, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin10x641511, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin10x861607, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: MediaPackWin10x641607, state: Present, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: pmsshutdown, state: Absent, cached: None
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: vcredist_repair, state: Absent, cached: Complete
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: vcredist, state: Absent, cached: Complete
[2EA4:21FC][2017-06-17T22:12:41]i101: Detected package: pms, state: Absent, cached: Complete
[2EA4:21FC][2017-06-17T22:12:41]i052: Condition ‘VersionNT >= v6.1’ evaluates to true.
[2EA4:21FC][2017-06-17T22:12:41]i052: Condition ‘NOT ((VersionNT = v6.1) AND ((NOT ServicePackLevel) OR (ServicePackLevel < 1)))’ evaluates to true.
[2EA4:21FC][2017-06-17T22:12:41]i052: Condition ‘NOT ((VersionNT = v6.3) AND (KB2919355_x86 <> 112 AND KB2919355_amd64 <> 112))’ evaluates to true.
[2EA4:21FC][2017-06-17T22:12:41]i199: Detect complete, result: 0x0
[2EA4:0FB0][2017-06-17T22:12:42]i000: Setting numeric variable ‘EulaAcceptCheckbox’ to value 0
[2EA4:21FC][2017-06-17T22:12:42]i200: Plan begin, 16 packages, action: Install
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT=v6.1 AND NOT VersionNT64 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin7x86
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT=v6.1 AND VersionNT64 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin7x64
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT=v6.2 AND NOT VersionNT64 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin8x86
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT=v6.2 AND VersionNT64 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin8x64
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT=v6.3 AND NOT VersionNT64 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin81x86
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT=v6.3 AND VersionNT64 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin81x64
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT>=v10.0 AND NOT VersionNT64 AND WinRegCurrentBuildNumber=10240 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x86
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT>=v10.0 AND VersionNT64 AND WinRegCurrentBuildNumber=10240 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x64
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT>=v10.0 AND NOT VersionNT64 AND WinRegReleaseID=1511 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x861511
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT>=v10.0 AND VersionNT64 AND WinRegReleaseID=1511 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x641511
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT>=v10.0 AND NOT VersionNT64 AND WinRegReleaseID=1607 AND WinRegInstallationType~=“Client”’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x861607
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘VersionNT>=v10.0 AND VersionNT64 AND WinRegReleaseID=1607 AND WinRegInstallationType~=“Client”’ evaluates to true.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: MediaPackWin10x641607
[2EA4:21FC][2017-06-17T22:12:42]i000: Setting string variable ‘WixBundleRollbackLog_pmsshutdown’ to value ‘C:\Users\MATRIX~1\AppData\Local\Temp\Plex Media Server_20170617221241_000_pmsshutdown_rollback.log’
[2EA4:21FC][2017-06-17T22:12:42]i000: Setting string variable ‘WixBundleLog_pmsshutdown’ to value ‘C:\Users\MATRIX~1\AppData\Local\Temp\Plex Media Server_20170617221241_000_pmsshutdown.log’
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘Bad_VCRedist’ evaluates to false.
[2EA4:21FC][2017-06-17T22:12:42]w321: Skipping dependency registration on package with no dependency providers: vcredist_repair
[2EA4:21FC][2017-06-17T22:12:42]i052: Condition ‘NOT Bad_VCRedist’ evaluates to true.
[2EA4:21FC][2017-06-17T22:12:42]i000: Setting string variable ‘WixBundleLog_vcredist’ to value ‘C:\Users\MATRIX~1\AppData\Local\Temp\Plex Media Server_20170617221241_001_vcredist.log’
[2EA4:21FC][2017-06-17T22:12:42]i000: Setting string variable ‘WixBundleRollbackLog_pms’ to value ‘C:\Users\MATRIX~1\AppData\Local\Temp\Plex Media Server_20170617221241_002_pms_rollback.log’
[2EA4:21FC][2017-06-17T22:12:42]i000: Setting string variable ‘WixBundleLog_pms’ to value ‘C:\Users\MATRIX~1\AppData\Local\Temp\Plex Media Server_20170617221241_002_pms.log’
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin7x86, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin7x64, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin8x86, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin8x64, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin81x86, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin81x64, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin10x86, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin10x64, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin10x861511, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin10x641511, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin10x861607, state: Present, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: MediaPackWin10x641607, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: pmsshutdown, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: vcredist_repair, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: Yes, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: vcredist, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: No, uncache: No, dependency: None
[2EA4:21FC][2017-06-17T22:12:42]i201: Planned package: pms, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[2EA4:21FC][2017-06-17T22:12:42]i299: Plan complete, result: 0x0
[2EA4:21FC][2017-06-17T22:12:42]i300: Apply begin
[2EA4:21FC][2017-06-17T22:12:42]i010: Launching elevated engine process.
[2EA4:21FC][2017-06-17T22:12:42]i011: Launched elevated engine process.
[2EA4:21FC][2017-06-17T22:12:43]i012: Connected to elevated engine.
[2D84:307C][2017-06-17T22:12:43]i358: Pausing automatic updates.
[2D84:307C][2017-06-17T22:12:43]i359: Paused automatic updates.
[2D84:307C][2017-06-17T22:12:43]i360: Creating a system restore point.
[2D84:307C][2017-06-17T22:12:43]i361: Created a system restore point.
[2D84:307C][2017-06-17T22:12:43]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{de82078e-91f7-4bd1-8ea5-182dc0b59de6}, options: 0x7, disable resume: No
[2D84:307C][2017-06-17T22:12:43]i000: Caching bundle from: ‘C:\Users\MATRIX~1\AppData\Local\Temp{0DD0F6D3-7C68-4C4D-9302-250BB66AC032}.be\pms.exe’ to: ‘C:\ProgramData\Package Cache{de82078e-91f7-4bd1-8ea5-182dc0b59de6}\pms.exe’
[2D84:307C][2017-06-17T22:12:43]i320: Registering bundle dependency provider: {de82078e-91f7-4bd1-8ea5-182dc0b59de6}, version: 1.5.6.3790
[2D84:307C][2017-06-17T22:12:43]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{de82078e-91f7-4bd1-8ea5-182dc0b59de6}, resume: Active, restart initiated: No, disable resume: No
[2D84:2194][2017-06-17T22:12:43]i305: Verified acquired payload: pmsshutdown at path: C:\ProgramData\Package Cache.unverified\pmsshutdown, moving to: C:\ProgramData\Package Cache{C3C981E2-1297-45A5-8862-FDBE25DEFE48}v1.5.3790\pms-shutdown.msi.
[2D84:2194][2017-06-17T22:12:43]i304: Verified existing payload: vcredist at path: C:\ProgramData\Package Cache\72211BD2E7DFC91EA7C8FAC549C49C0543BA791B\vcredist_x86.exe.
[2D84:2194][2017-06-17T22:12:43]i304: Verified existing payload: pms at path: C:\ProgramData\Package Cache{BA932E6A-A256-4A56-BF50-54D0AEE9FAE3}v1.5.3790\pms.msi.
[2D84:307C][2017-06-17T22:12:43]i323: Registering package dependency provider: {C3C981E2-1297-45A5-8862-FDBE25DEFE48}, version: 1.5.3790, package: pmsshutdown
[2D84:307C][2017-06-17T22:12:43]i301: Applying execute package: pmsshutdown, action: Install, path: C:\ProgramData\Package Cache{C3C981E2-1297-45A5-8862-FDBE25DEFE48}v1.5.3790\pms-shutdown.msi, arguments: ’ ARPSYSTEMCOMPONENT=“1” MSIFASTINSTALL=“7” INSTALLLOCATION=“C:\Program Files (x86)\Plex\Plex Media Server”’
[2D84:307C][2017-06-17T22:12:48]e000: Error 0x80070643: Failed to install MSI package.
[2D84:307C][2017-06-17T22:12:48]e000: Error 0x80070643: Failed to execute MSI package.
[2EA4:21FC][2017-06-17T22:12:48]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[2EA4:21FC][2017-06-17T22:12:48]i319: Applied execute package: pmsshutdown, result: 0x80070643, restart: None
[2EA4:21FC][2017-06-17T22:12:48]e000: Error 0x80070643: Failed to execute MSI package.
[2D84:307C][2017-06-17T22:12:48]i318: Skipped rollback of package: pmsshutdown, action: Uninstall, already: Absent
[2EA4:21FC][2017-06-17T22:12:48]i319: Applied rollback package: pmsshutdown, result: 0x0, restart: None
[2D84:307C][2017-06-17T22:12:48]i329: Removed package dependency provider: {C3C981E2-1297-45A5-8862-FDBE25DEFE48}, package: pmsshutdown
[2D84:307C][2017-06-17T22:12:48]i351: Removing cached package: pmsshutdown, from path: C:\ProgramData\Package Cache{C3C981E2-1297-45A5-8862-FDBE25DEFE48}v1.5.3790
[2D84:307C][2017-06-17T22:12:48]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{de82078e-91f7-4bd1-8ea5-182dc0b59de6}, resume: None, restart: None, disable resume: No
[2D84:307C][2017-06-17T22:12:48]i330: Removed bundle dependency provider: {de82078e-91f7-4bd1-8ea5-182dc0b59de6}
[2D84:307C][2017-06-17T22:12:48]i352: Removing cached bundle: {de82078e-91f7-4bd1-8ea5-182dc0b59de6}, from path: C:\ProgramData\Package Cache{de82078e-91f7-4bd1-8ea5-182dc0b59de6}
[2D84:307C][2017-06-17T22:12:48]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{de82078e-91f7-4bd1-8ea5-182dc0b59de6}, resume: None, restart initiated: No, disable resume: No
[2EA4:21FC][2017-06-17T22:12:48]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
Now I only get The older version of stopping plex cannot be removed
0x80070634 (this has always been there)
Be sure Windows has no pending updates that might be blocking your install of Plex
Is there no way to force the install?
Seriously!!!
Tried installing old version from http://www.filehorse.com/download-plex-media-server/29449/download/
It WORX!!
I still cant upgrade to lastet version though without getting error
Something is ffed up in the latest plex versions both normal and plex pass downloads
Have you tried version 1.6.1? Besides I think 1.5.3xxx sucks anyways. There is also v1.7.x out now.
Tried everything, windows fix says there is nothing wrong
