Server Version#: 1.40.3.8555
I run plex on an unraid server using the official docker image. I am currently on 1.40.3.8555-fef15d30c. When I try to update the container to 1.40.4.8679-424562606 I run into “Unable to set up server: sqlite3_statement_backend::loadRS: malformed JSON” in the logs and the server doesn’t start. I will note that I was actually on 1.40.2.8395-c67dce28e, and when I tried to update I got the error. So I went 1 tag at a time and found 1.40.4.8679-424562606 to be the offending version.
Last time I had a similar issue I had to rebuild everything from scratch and I really don’t want to keep doing that just to update. If anyone can please help that would be wonderful.
