Plex works after installing, stops after restarting machine
Server Version#: 1.21.1.3876
I am facing an extremely weird issue.
My server was running perfectly fine till yesterday when it became offline. I checked and the server was running, but couldn’t connect using “http://127.0.0.1:32400/web/index.html” or from my TV. I restarted the machine, nothing happened.
Then I ended up uninstalling and reinstalling my plex server, and it worked. So, I replaced the following folders in the Plex Media Server: Plug-in Support, Metadata, Media. This point the server was running fine and I was able to play stuff on the machine and on the TV. Night, I turned off the laptop, and in the morning it stopped working again.
Reinstalled>copied 3 folders - works fine
Restarted Laptop>Stops working
The cycle continues.
Anyone seen this behavior before? Any help is deeply appreciated. Uploading the logs herewith as well.
Plex Media Server.log (81.8 KB)
