Help Me - Plex Server not available
Server Version#:Lastest
Player Version#:Lastest
debug_plex.txt (1.3 KB)
Hello, I’ve the problem as in the attachments.
Each time I must to re-install plex-server, when I restart my PC.
The problem its just for my local library. My connection is fine
Thank you
Salvatore
What does http://127.0.0.1:32400/web show?
Impossibile raggiungere questa pagina
127.0.0.1 ha rifiutato la connessione.
Prova a:
Prova a:
All is happened when I reinstalled Windows 10pro, preserving all apps. I didn’t make a clean installation.
So sounds like plex isnt running.
can you post a copy of your server logs ?
I attacched it to the first post as txt file
That is a copy of your player log, not the server log that I am asking for. Can you zip and upload the contents of %LOCALAPPDATA%\Plex Media Server\Logs
Plexlogs_.zip (2.2 MB)
Just copied 2024 files, all folder was more than 60Mbyte
