Server Version# : nas version 1.23.2.4656
Player Version#: plexamp v3.4.7
the next song bengin to play before the previous song has finined !!!
it means you will hear two music
not all songs some of them have the problem
Edit your music library
go to the “Advanced” tab
DISable “store track progress”
Also: Open the settings dialog of Plexamp
Playback - Sweet Fades ← DISable
As OttoKerner said, it’s sweet fades. It fades the last 5ish seconds of one song with the next. On some songs, it works really “sweet”. On some, it sucks sewer water.
Roll of the dice. Disable it or keep it and hope for good “sweet” fades.
There is no fixed time for the fade.
Instead, the loudness developments of the previous track and the following track are both taken into account to find the length of time where both tracks can be overlaid without the volume getting too high.
In other words: the time will be computed individually for every pair of tracks
