Plexamp 3.0.2 no longer working in Pop!_OS 20.04
Plexamp 3.0.2 no longer renders a window and is therefore unusable today in Pop!_OS 20.04, was working yesterday in 19.10.
Not sure if this helps:
I just updated to Pop!_OS 20.04 tonight and am able to run Plexamp 3.0.2. My terminal output is similar to yours. The difference appears to be that there are no “… seccomp-bpf failure in syscall 0230” error messages. There are a few other threads which suggest trying either the --disable-seccomp-filter-sandbox or --no-sandbox command-line options for similar failures on other distributions. It may be worth a try here.
–no-sandbox worked
Thanks my friend
No problem, glad it worked.
