Plexamp 3.0 not starting on Arch linux
3.1.0 is out. Still not working for me on Arch.
QApplication: invalid style override ‘gtk’ passed, ignoring it.
Available styles: Breeze, kvantum-dark, kvantum, Oxygen, QtCurve, Windows, Fusion
xdg-mime: application argument missing
Try ‘xdg-mime --help’ for more information.
Couldn’t install shortcut for MediaPlayPause.
Couldn’t install shortcut for MediaPreviousTrack.
Couldn’t install shortcut for MediaNextTrack.
Started Media Service: false
Linux: Registering MPRIS service.
[28925:0603/072647.774117:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
(node:28932) Electron: Loading non context-aware native modules in the renderer process is deprecated and will stop working at some point in the future, please see https://github.com/electron/electron/issues/18397 for more information
Checking for update
(plexamp:28840): LIBDBUSMENU-GLIB-WARNING **: 07:26:48.379: About to Show called on an item wihtout submenus. We’re ignoring it.
(plexamp:28840): LIBDBUSMENU-GLIB-WARNING **: 07:26:48.423: About to Show called on an item wihtout submenus. We’re ignoring it.
Update for version 3.1.0 is not available (latest version: 3.1.0, downgrade is disallowed).
checkForUpdatesAndNotify called, downloadPromise is null
Running with --disable-seccomp-filter-sandbox worked for me to fix the problem on Ubuntu too.
( Plexamp runs without this, and can be controlled by playerctl, but the gui will not show. )
Latest version works! I got past the sign-in window, logged in and the app seems to be working. However I can’t control it with my media keys, like on windows. Ctrl+Alt+up/down arrow works to adjust Plexamp volume though.
are you using the AUR version? it always (since 3.0) worked fine for me, including media keys [prev, play/pause, next]. volume, for me, is managed via gnome.
link: https://aur.archlinux.org/packages/plexamp-appimg
Did not matter which version I used. It was always either not starting at all, or getting stuck on the sign-in window. Now working and media keys work too until I play something on youtube. Then media keys will switch to youtube instead and will stay there until I select PlexAmp window again. Using KDE.
I’ve had success running it on debian Linux debian 4.19.0-6-amd64 #1 SMP Debian 4.19.67-2 (2019-08-28) x86_64 GNU/Linux
Running the appimage as follows allows the sign in portion to function properly (you may have to look around for the browser that it sent the authentication page to, or maybe you need to just have it open). The app functions great – I made shell script to run it even. I imagine this may work for a lot of the other posters here.
Spread this around if it works for you too:
./Plexamp-3.1.1.AppImage --disable-seccomp-filter-sandbox --no-sandbox
I’ll add that I did have all the problems the previous posts are mentioning such as the app not running and the sign in button not working. The appimage needs to be executable chmod +x ./Plexamp-3.1.1.AppImage and the above two arguments seem to fix both issues for me.
Of course, use at your own risk, you are then allowing the application un-sandboxed access to your computer.
I was able to launch and sign in with the flags mentioned in this thread. However, when attempting to play anything, it just results in a blank off-gray window.
System:    Kernel: 5.7.9-200.fc32.x86_64 x86_64 bits: 64 compiler: gcc v: 2.34-3.fc32)
           Desktop: Cinnamon 4.6.6 wm: muffin dm: GDM, LightDM
           Distro: Fedora release 32 (Thirty Two)
This is the command I needed to use in order to get it working in Fedora 32
LD_PRELOAD=/usr/lib64/libcrypto.so.1.0.2o ~/bin/Plexamp-3.?.?.AppImage --disable-seccomp-filter-sandbox
See my reply above ^^
Thank you, this seems to have worked!
