Plexamp 3.2.0 desktop - no volume control?
Great job with Plexamp! So cool to have casting back. Phew!
One thing I’ve just noticed - the release notes say that volume controls should be in the cast menu… but i’m not seeing them anywhere… any thoughts?
thanks…
windows 10, casting to an LG tv…
I have the same issue (Windows casting to Sonos - Yay!!) It’s there in the cast menu when you first start your cast but then it disappears. I am using KB shortcuts ATM but having volume accessible from the app interface would be ideal.
Sometimes Sonos isn’t good at advertising volume support, there’s a bug filed (with our Sonos cloud proxy). Web (e.g. TV) has a similar bug, also filed, when things are actually playing the volume control should be there.
Yeah, I’ve noticed (after making the above observation) that it is inconsistent, but there more often then not.
Actually, in my case, this was solved by option out of the early access program in the LG app. Volume controls are available when the old version is running on the TV, but not when the early access version is running. WebOS is current on my TV.
