Plexamp - volume control issues
Hi all,
First, let me say that I love Plexamp, this is actually what I use the most out of all Plex players and great feature. As Google Music is sun setting, I was looking for a replacement that allows me to upload all my music library in the cloud, and offering a great user interface and sync between devices. When I discovered Plex and Plexamp, I felt right away that was THE solution.
But, I have a question, It doesn’t seem to have a volume control part of the Plexamp, particularly on the desktop version (I am use a Macbook Pro). I use Looback Audio from Rogue Amobea, as a workaround, which is an amazing MacOS application offering virtual audio cable configurations, which allows me to control the output volume in a sense. I don’t use the Macbook Pro device volume control (on the keyboard), as my sound goes out via USB in an external audio mixer, and then goes to active speakers.
I have experienced a nasty distortion recently, and I went on a quest to find the culprit, I did some test with my speakers, I even sent back my audio mixer thinking it was faulty, it’s not, Yamaha didn’t find anything faulty. I don’t think it’s Plexamp, as I experienced the distortion with VLC or even with other input in my mixer (via RCA or XLR).
But again, my question is how other users manage the volume output of the plexamp app on their desktop, when I disable Loopback software, the volume is crazy loud and it seems I have no way to put the volume down as there are no volume control on the plexamp ‘app’.
Thanks for reading and for your feedback everyone!
Thanks for the kind words!
Next version will have an accessible volume slider.
For now, you can use Commandl+Option+ up/down arrow to raise/lower Plexamp’s soft volume.
Thanks for your reply.
I didn’t know this shortcut, nice.
I actually just bought SoundSource from Rogue Amoeba, and that helps a lot.
Offering a volume fader I can access with the mouse but also allowing to use the physical volume button of the mac keyboard.
Good to know a new version is coming!
Cheers and thanks for your work and great products!
and maybe a “close app” button.
In windows… the only way to close it is alt-f4, right click on the start menu aso…
I mean… release a program that’s got no close app button ? :stuck_out_tongue:
Oh and i look forward to the volume slider ! :smiley:
oooh… and maybe an apple tv version in the future ? :slight_smile:
why would you want to quit the app? :scream:
no current plans
oohh… and maybe a “cast” button :slight_smile:
airplay, google cast, miracast aso :slight_smile:
cast yes.
airplay is already there :sweat_smile:
google cast is in the next release.
miracast can die a flaming :skull:
Hehe. Never used miracast. :stuck_out_tongue:
But I was thinking about adding the casting to the windows version :slight_smile:
oooohh… the lies ! the lies !! :wink:
No volume og close app button on the new plexamp release.
:stuck_out_tongue:
On desktop, player volume is tucked away in the cast dialog :slightly_smiling_face: no lies!
No offense, but that was a stupid design choice :stuck_out_tongue: hehe
you can’t say “no offense” and then be offensive. THAT’S NOT HOW IT WORKS!
It’s there at least! thank you Elan and the team.
But I agree that it’s a bit hard to find the first time, and then even knowing where it is to access it.
I know design and UX is really hard, and I appreciate Plexamp for its kind of minimalist design.
Having said that, it’s a bit counter intuitive to me indeed to have to go to the cast ‘menu’ / ‘button’, just to adjust the volume.
Logged in to just wonder about this. Looking forward to the update.
Yeah… sorry about that. Poor choice of words on my part. :confused:
Any chance to implement music video playback in the plexamp app ?
no current plans. we really want to make the app awesome for audio.
It looks like control+ALT + up/down arrows stopped working as volume controls for me. Anyone else experiencing this? I have the latest version 3.3.1
Go into settings and set whatever global shortcuts you want :slight_smile:
Oh nice, I didnt even know that was added. Looks like it defaulted to Mac keys when that feature was implemented.
Thanks for the fix
