Plexamp 3.8.2 on Linux Quickly Turns into a Grey Screen and Stops Working
Have you tried it on any other Linux versions?
If so can you log in there?
If that works, what happens if you copy your config from the successful login machine to the machine you’re having issues on?
Just tried Fedora 35, still can’t login. I’ve actually never been able to login to plexamp, always get the grey box after login.
Actually had a new issue on Fedora
Started Media Service: false
Linux: Registering MPRIS service.
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[31181:1219/170520.810284:FATAL:gpu_data_manager_impl_private.cc(415)] GPU process isn't usable. Goodbye.
Trace/breakpoint trap (core dumped)
So I ran with Plexamp-3.8.2.AppImage' --no-sandbox
It shows me the login screen, I put my details in and then grey box again.
I just installed it via the unofficial Flatpak and it opens fine.
I got a different crash this time, but I got a stack trace at least:
(lldb) c
Process 3585 resuming
Process 3585 stopped
* thread #20, name = 'Network Manager', stop reason = signal SIGSEGV: invalid address (fault address: 0x0)
    frame #0: 0x00007f9692f72382 treble.node`look_str_cb + 146
treble.node`look_str_cb:
->  0x7f9692f72382 <+146>: callq  *0x60(%rbp)
    0x7f9692f72385 <+149>: movq   0x10(%rsp), %r15
    0x7f9692f7238a <+154>: testq  %r15, %r15
    0x7f9692f7238d <+157>: je     0x7f9692f72358            ; <+104>
(lldb) bt
  * frame #0: 0x00007f9692f72382 treble.node`look_str_cb + 146
    frame #1: 0x00007f9692f7c67c treble.node`lh_doall_arg + 76
    frame #2: 0x00007f9693046b81 treble.node`engine_table_doall + 49
    frame #3: 0x00007f9692f727ca treble.node`ENGINE_pkey_asn1_find_str + 90
    frame #4: 0x00007f9692fa3dea treble.node`EVP_PKEY_asn1_find_str + 74
    frame #5: 0x00007f9692f300c2 treble.node`ssl_create_cipher_list + 354
    frame #6: 0x00007f9692f28251 treble.node`SSL_CTX_new + 513
    frame #7: 0x00007f9692f01005 treble.node`ossl_connect_step1 + 357
    frame #8: 0x00007f9692f02db0 treble.node`ossl_connect_common + 288
    frame #9: 0x00007f9692eeef0d treble.node`Curl_ssl_connect_nonblocking + 93
    frame #10: 0x00007f9692eca952 treble.node`https_connecting + 18
    frame #11: 0x00007f9692ecbdbb treble.node`Curl_http_connect + 203
    frame #12: 0x00007f9692ed9322 treble.node`multi_runsingle + 1922
    frame #13: 0x00007f9692eda2de treble.node`curl_multi_perform + 190
    frame #14: 0x00007f9692e75137 treble.node`NetworkRequestManager::run() + 135
    frame #15: 0x00007f9692530874 libstdc++.so.6`___lldb_unnamed_symbol590$$libstdc++.so.6 + 20
    frame #16: 0x00007f969e935d80 libpthread.so.0`start_thread(arg=0x00007f9690458640) at pthread_create.c:481:8
    frame #17: 0x00007f969cfd0b6f libc.so.6`__clone at clone.S:95
(lldb) c
Process 3585 exited with status = 11 (0x0000000b)
I’ve managed to capture the original segfault that I saw, although the stack trace doesn’t seem particularly helpful.
(lldb) c
Process 25596 resuming
Process 25596 stopped
* thread #18, name = 'Network Manager', stop reason = signal SIGSEGV: invalid address (fault address: 0x39)
    frame #0: 0x00005615479f10b4 plexamp`___lldb_unnamed_symbol165$$plexamp + 35204
plexamp`___lldb_unnamed_symbol165$$plexamp:
->  0x5615479f10b4 <+35204>: movb   $0x21, 0x39
    0x5615479f10bc <+35212>: popq   %rbp
    0x5615479f10bd <+35213>: retq
    0x5615479f10be <+35214>: int3
(lldb) bt
  * frame #0: 0x00005615479f10b4 plexamp`___lldb_unnamed_symbol165$$plexamp + 35204
    frame #1: 0x000056154689557b plexamp`___lldb_unnamed_symbol45$$plexamp + 3835
Edit: I figured out how to get a stack trace for all threads.
(lldb) bt all
  thread #1, name = 'plexamp'
    frame #0: 0x000056154bd0a890 plexamp
    frame #1: 0x00005615469cc219 plexamp
    frame #2: 0x000056154bd0df9f plexamp
    frame #3: 0x000056154672eb59 plexamp
    frame #4: 0x000056154ba9c09f plexamp
    frame #5: 0x0000561549853f4c plexamp
    frame #6: 0x0000561549c2ea32 plexamp
    frame #7: 0x0000561546b55fe5 plexamp
    frame #8: 0x00005615491c9c0e plexamp
    frame #9: 0x000056154694a462 plexamp`___lldb_unnamed_symbol49$$plexamp + 386
    frame #10: 0x00005615465a826e plexamp
    frame #11: 0x000056154620ebf2 plexamp
    frame #12: 0x000056154620e69e plexamp
    frame #13: 0x000056154b3dca2e plexamp`___lldb_unnamed_symbol863$$plexamp + 9966
    frame #14: 0x0000561546dde6d7 plexamp
    frame #15: 0x0000561546f7aa79 plexamp
    frame #16: 0x000056154c18e11a plexamp
    frame #17: 0x000056154acba63d plexamp
    frame #18: 0x000056154acb8172 plexamp
    frame #19: 0x000056154acb8872 plexamp
    frame #20: 0x000056154a82682f plexamp
    frame #21: 0x00007f0436e397ed libc.so.6`__libc_start_main(main=0x000056154a826650, argc=14, argv=0x00007ffcf4080678, init=<unavailable>, fini=<unavailable>, rtld_fini=<unavailable>, stack_end=0x00007ffcf4080668) at libc-start.c:332:16
    frame #22: 0x000056154a81053a plexamp`_start + 42
  thread #2, name = 'ThreadPoolServi'
    frame #0: 0x00007f0436f0ee96 libc.so.6`epoll_wait(epfd=6, events=0x00001c59ef201d80, maxevents=32, timeout=-1) at epoll_wait.c:30:10
    frame #1: 0x00005615463c366d plexamp
    frame #2: 0x000056154b418ceb plexamp
    frame #3: 0x000056154b3f1829 plexamp
    frame #4: 0x0000561546dde6d7 plexamp
    frame #5: 0x0000561546f7aa79 plexamp
    frame #6: 0x0000561546f7a7ed plexamp
    frame #7: 0x000056154b3ede7d plexamp`___lldb_unnamed_symbol863$$plexamp + 80701
    frame #8: 0x000056154b3efe96 plexamp`___lldb_unnamed_symbol863$$plexamp + 88918
    frame #9: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0434420640) at pthread_create.c:481:8
    frame #10: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #3, name = 'Chrome_ChildIOT'
    frame #0: 0x00007f0436f0ee96 libc.so.6`epoll_wait(epfd=24, events=0x00001c59ef201c00, maxevents=32, timeout=-1) at epoll_wait.c:30:10
    frame #6: 0x000056154b3ede7d plexamp`___lldb_unnamed_symbol863$$plexamp + 80701
    frame #7: 0x000056154b3efe96 plexamp`___lldb_unnamed_symbol863$$plexamp + 88918
    frame #8: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f043341e640) at pthread_create.c:481:8
    frame #9: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #5, name = 'GpuMemoryThread'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f043241b578, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #1: 0x00007f0438879c30 libpthread.so.0`__pthread_cond_wait at pthread_cond_wait.c:504:10
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00007f043241b550, mutex=0x00007f043241b528) at pthread_cond_wait.c:619
    frame #3: 0x00005615461c333d plexamp
    frame #4: 0x0000561546560626 plexamp
    frame #5: 0x000056154656017e plexamp
    frame #6: 0x000056154b3dca0f plexamp`___lldb_unnamed_symbol863$$plexamp + 9935
    frame #7: 0x0000561546dde6d7 plexamp
    frame #8: 0x0000561546f7aa79 plexamp
    frame #9: 0x000056154b3ede7d plexamp`___lldb_unnamed_symbol863$$plexamp + 80701
    frame #10: 0x000056154b3efe96 plexamp`___lldb_unnamed_symbol863$$plexamp + 88918
    frame #11: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f043241c640) at pthread_create.c:481:8
    frame #12: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #6, name = 'Compositor'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f0431c1a588, expected=0, clockid=<unavailable>, abstime=0x00007f0431c1a430, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #1: 0x00007f0438879f44 libpthread.so.0`__pthread_cond_timedwait at pthread_cond_wait.c:504:10
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f0431c1a560, mutex=0x00007f0431c1a538, abstime=0x00007f0431c1a430) at pthread_cond_wait.c:637
    frame #3: 0x00005615465608b8 plexamp`___lldb_unnamed_symbol27$$plexamp + 376
    frame #4: 0x00005615465603c7 plexamp
    frame #5: 0x000056154b3dca24 plexamp`___lldb_unnamed_symbol863$$plexamp + 9956
    frame #6: 0x0000561546dde6d7 plexamp
    frame #7: 0x0000561546f7aa79 plexamp
    frame #8: 0x000056154af5fae9 plexamp
    frame #9: 0x000056154b3efe96 plexamp`___lldb_unnamed_symbol863$$plexamp + 88918
    frame #10: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0431c1b640) at pthread_create.c:481:8
    frame #11: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #7, name = 'ThreadPoolSingl'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f0431419608, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00007f04314195e0, mutex=0x00007f04314195b8) at pthread_cond_wait.c:619
    frame #6: 0x000056154b3ed00a plexamp`___lldb_unnamed_symbol863$$plexamp + 77002
    frame #7: 0x00005615470e2830 plexamp
    frame #8: 0x0000561548b7f53d plexamp`___lldb_unnamed_symbol573$$plexamp + 125981
    frame #10: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f043141a640) at pthread_create.c:481:8
  thread #8, name = 'CompositorTileW'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59ef1ff32c, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00001c59ef1ff300, mutex=0x00001c59ef1ff230) at pthread_cond_wait.c:619
    frame #4: 0x00005615461c2ce7 plexamp
    frame #5: 0x000056154b3efe96 plexamp`___lldb_unnamed_symbol863$$plexamp + 88918
    frame #6: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0430c19640) at pthread_create.c:481:8
    frame #7: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #9, name = 'CompositorTileW'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59ef1ff328, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #6: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0430418640) at pthread_create.c:481:8
  thread #10, name = 'CompositorTileW'
    frame #6: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f042fc17640) at pthread_create.c:481:8
  thread #11, name = 'CompositorTileW'
    frame #6: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f042f416640) at pthread_create.c:481:8
  thread #12, name = 'CompositorTileW'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59ef1ff36c, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00001c59ef1ff340, mutex=0x00001c59ef1ff230) at pthread_cond_wait.c:619
    frame #6: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f042ec15640) at pthread_create.c:481:8
  thread #13, name = 'plexamp'
    frame #0: 0x00007f0436f0ee96 libc.so.6`epoll_wait(epfd=13, events=0x00007f042e4037c0, maxevents=1, timeout=-1) at epoll_wait.c:30:10
    frame #1: 0x000056154a959c5c plexamp
    frame #2: 0x000056154a931768 plexamp
    frame #3: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f042e404640) at pthread_create.c:481:8
    frame #4: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #14, name = 'plexamp'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x000056154c92a5c0, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x000056154c92a598, mutex=0x000056154c92a570) at pthread_cond_wait.c:619
    frame #3: 0x000056154a8210b9 plexamp`uv_cond_wait + 9
    frame #4: 0x000056154a812770 plexamp
    frame #5: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f042c39a640) at pthread_create.c:481:8
    frame #6: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #15, name = 'plexamp'
    frame #5: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f042bb99640) at pthread_create.c:481:8
  thread #16, name = 'plexamp'
    frame #5: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f042b398640) at pthread_create.c:481:8
  thread #17, name = 'plexamp'
    frame #5: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f042ab97640) at pthread_create.c:481:8
  thread #19, name = 'Logger Thread'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59ef48b648, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00001c59ef48b620, mutex=0x00001c59ef48b5f8) at pthread_cond_wait.c:619
    frame #3: 0x00007f042c468d40 libstdc++.so.6`std::condition_variable::wait(std::unique_lock<std::mutex>&) + 16
    frame #4: 0x00007f042cd7b6d3 treble.node`FileLogger::dequeueAndLog() + 115
    frame #5: 0x00007f042cd7b898 treble.node`FileLogger::outputWorker() + 56
    frame #6: 0x00007f042c46e874 libstdc++.so.6`___lldb_unnamed_symbol590$$libstdc++.so.6 + 20
    frame #7: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0428b93640) at pthread_create.c:481:8
    frame #8: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #20, name = 'plexamp'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59ef49ae60, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00001c59ef49ae38, mutex=0x00001c59ef49ae10) at pthread_cond_wait.c:619
  thread #26, name = 'plexamp'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59ef5c6c30, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00001c59ef5c6c08, mutex=0x00001c59ef5c6be0) at pthread_cond_wait.c:619
    frame #4: 0x00007f042cd2945e treble.node`AudioPlayer::frequencyValueThread() + 446
    frame #5: 0x00007f042c46e874 libstdc++.so.6`___lldb_unnamed_symbol590$$libstdc++.so.6 + 20
    frame #6: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0420b82640) at pthread_create.c:481:8
  thread #27, name = 'plexamp'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59ef5c6cc8, expected=0, clockid=<unavailable>, abstime=0x00007f04203806a0, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00001c59ef5c6ca0, mutex=0x00001c59ef5c6cd0, abstime=0x00007f04203806a0) at pthread_cond_wait.c:637
    frame #3: 0x00007f042cd2d53c treble.node`AudioPlayer::stateObserverThread() + 1884
    frame #4: 0x00007f042c46e874 libstdc++.so.6`___lldb_unnamed_symbol590$$libstdc++.so.6 + 20
    frame #5: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0420381640) at pthread_create.c:481:8
  thread #28, name = 'Opening Thread'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f042d2de04c, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00007f042d2de020, mutex=0x00007f042d2de060) at pthread_cond_wait.c:619
    frame #4: 0x00007f042cd55beb treble.node`CachingFileReader::DequeueBufferingNotification() + 155
    frame #6: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f041f37f640) at pthread_create.c:481:8
  thread #32, name = 'threaded-ml'
    frame #0: 0x00007f0436f03f7f libc.so.6`__GI___poll(fds=0x00001c59ef4c1ba0, nfds=2, timeout=262) at poll.c:29:10
    frame #1: 0x00007f042533ca02 libpulse.so.0`___lldb_unnamed_symbol109$$libpulse.so.0 + 50
    frame #2: 0x00007f042532e449 libpulse.so.0`pa_mainloop_poll + 233
    frame #3: 0x00007f042532eac7 libpulse.so.0`pa_mainloop_iterate + 39
    frame #4: 0x00007f042532eb70 libpulse.so.0`pa_mainloop_run + 32
    frame #5: 0x00007f042533cad9 libpulse.so.0`___lldb_unnamed_symbol110$$libpulse.so.0 + 105
    frame #6: 0x00007f04252dcaef libpulsecommon-15.0.so`___lldb_unnamed_symbol134$$libpulsecommon-15.0.so + 79
    frame #7: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0422b86640) at pthread_create.c:481:8
  thread #33, name = 'threaded-ml'
    frame #0: 0x00007f0436f03f7f libc.so.6`__GI___poll(fds=0x00001c59f17fa6c0, nfds=2, timeout=-1) at poll.c:29:10
    frame #7: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0423387640) at pthread_create.c:481:8
  thread #34, name = 'plexamp'
    frame #0: 0x00007f0436f03f7f libc.so.6`__GI___poll(fds=0x00007f042137fd70, nfds=1, timeout=100) at poll.c:29:10
    frame #1: 0x00007f04371290a5 libasound.so.2`___lldb_unnamed_symbol301$$libasound.so.2 + 197
    frame #2: 0x00007f04371293e3 libasound.so.2`snd_pcm_wait + 35
    frame #3: 0x00007f042ca0a885 libbass.so
    frame #4: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0421383640) at pthread_create.c:481:8
    frame #5: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
  thread #35, name = 'plexamp'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f042cc165e0, expected=0, clockid=<unavailable>, abstime=0x00007f0422384790, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f042cc165b8, mutex=0x00007f042cc16590, abstime=0x00007f0422384790) at pthread_cond_wait.c:637
  thread #36, name = 'plexamp'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f042cc34830, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00007f042cc34808, mutex=0x00007f042cc347e0) at pthread_cond_wait.c:619
  thread #37, name = 'plexamp'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f042cc16580, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00007f042cc16558, mutex=0x00007f042cc16530) at pthread_cond_wait.c:619
  thread #38, name = 'plexamp'
  thread #39, name = 'plexamp'
  thread #40, name = 'ThreadPoolForeg'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f0426771628, expected=0, clockid=<unavailable>, abstime=0x00007f04267714d0, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f0426771600, mutex=0x00007f04267715d8, abstime=0x00007f04267714d0) at pthread_cond_wait.c:637
    frame #5: 0x000056154b3ed018 plexamp`___lldb_unnamed_symbol863$$plexamp + 77016
    frame #6: 0x00005615470e2aa6 plexamp
    frame #7: 0x00005615470e272d plexamp
    frame #9: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0426772640) at pthread_create.c:481:8
  thread #41, name = 'ThreadPoolForeg'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f041eb7d628, expected=0, clockid=<unavailable>, abstime=0x00007f041eb7d4d0, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f041eb7d600, mutex=0x00007f041eb7d5d8, abstime=0x00007f041eb7d4d0) at pthread_cond_wait.c:637
    frame #9: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f041eb7e640) at pthread_create.c:481:8
  thread #42, name = 'ThreadPoolForeg'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f0424388628, expected=0, clockid=<unavailable>, abstime=0x00007f04243884d0, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f0424388600, mutex=0x00007f04243885d8, abstime=0x00007f04243884d0) at pthread_cond_wait.c:637
    frame #9: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0424389640) at pthread_create.c:481:8
  thread #43, name = 'ThreadPoolForeg'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f041e37c628, expected=0, clockid=<unavailable>, abstime=0x00007f041e37c4d0, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f041e37c600, mutex=0x00007f041e37c5d8, abstime=0x00007f041e37c4d0) at pthread_cond_wait.c:637
    frame #9: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f041e37d640) at pthread_create.c:481:8
  thread #44, name = 'ThreadPoolForeg'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f041db7b628, expected=0, clockid=<unavailable>, abstime=0x00007f041db7b4d0, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f041db7b600, mutex=0x00007f041db7b5d8, abstime=0x00007f041db7b4d0) at pthread_cond_wait.c:637
    frame #9: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f041db7c640) at pthread_create.c:481:8
  thread #45, name = 'ThreadPoolForeg'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f042738f628, expected=0, clockid=<unavailable>, abstime=0x00007f042738f4d0, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f042738f600, mutex=0x00007f042738f5d8, abstime=0x00007f042738f4d0) at pthread_cond_wait.c:637
    frame #9: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0427390640) at pthread_create.c:481:8
  thread #46, name = 'ThreadPoolForeg'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00007f0421b83628, expected=0, clockid=<unavailable>, abstime=0x00007f0421b834d0, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879e60 libpthread.so.0`__pthread_cond_timedwait(cond=0x00007f0421b83600, mutex=0x00007f0421b835d8, abstime=0x00007f0421b834d0) at pthread_cond_wait.c:637
    frame #9: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0421b84640) at pthread_create.c:481:8
  thread #47, name = 'Opening Thread'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59f04ce150, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00001c59f04ce128, mutex=0x00001c59f04ce100) at pthread_cond_wait.c:619
  thread #48, name = 'Opening Thread'
    frame #0: 0x00007f04388800fa libpthread.so.0`__futex_abstimed_wait_common64(futex_word=0x00001c59f210e150, expected=0, clockid=<unavailable>, abstime=0x0000000000000000, private=<unavailable>, cancel=<unavailable>) at futex-internal.c:74:11
    frame #2: 0x00007f0438879b50 libpthread.so.0`__pthread_cond_wait(cond=0x00001c59f210e128, mutex=0x00001c59f210e100) at pthread_cond_wait.c:619
  thread #49, name = 'plexamp'
    frame #0: 0x00007f042ce83150 treble.node`OBJ_bsearch_ex_ + 64
    frame #1: 0x00007f042ce83302 treble.node`OBJ_obj2nid + 162
    frame #2: 0x00007f042cee8979 treble.node`X509_NAME_oneline + 169
    frame #3: 0x00007f042ced6f1e treble.node`x509_cb + 158
    frame #4: 0x00007f042cedf0ec treble.node`ASN1_item_ex_d2i + 2268
    frame #5: 0x00007f042cedf38b treble.node`ASN1_item_d2i + 75
    frame #6: 0x00007f042cf95006 treble.node`PEM_X509_INFO_read_bio + 518
    frame #7: 0x00007f042cef096f treble.node`X509_load_cert_crl_file + 79
    frame #8: 0x00007f042cef0b0a treble.node`by_file_ctrl + 170
    frame #9: 0x00007f042cee7cff treble.node`X509_STORE_load_locations + 63
    frame #10: 0x00007f042ce3fbf5 treble.node`ossl_connect_step1 + 3413
    frame #11: 0x00007f042ce40db0 treble.node`ossl_connect_common + 288
    frame #12: 0x00007f042ce2cf0d treble.node`Curl_ssl_connect_nonblocking + 93
    frame #13: 0x00007f042ce08952 treble.node`https_connecting + 18
    frame #14: 0x00007f042ce09dbb treble.node`Curl_http_connect + 203
    frame #15: 0x00007f042ce17322 treble.node`multi_runsingle + 1922
    frame #16: 0x00007f042ce182de treble.node`curl_multi_perform + 190
    frame #17: 0x00007f042cdabacc treble.node`NetworkRequest::process() + 140
    frame #18: 0x00007f042cd581c6 treble.node`CachingFileReader::stepNetwork(std::shared_ptr<NetworkRequest>&, unsigned long, std::shared_ptr<ConnectionTester>&) + 70
    frame #19: 0x00007f042cd5a7b9 treble.node`CachingFileReader::runBufferingThread(unsigned long) + 1289
    frame #20: 0x00007f042c46e874 libstdc++.so.6`___lldb_unnamed_symbol590$$libstdc++.so.6 + 20
    frame #21: 0x00007f0438873d80 libpthread.so.0`start_thread(arg=0x00007f0411c57640) at pthread_create.c:481:8
    frame #22: 0x00007f0436f0eb6f libc.so.6`__clone at clone.S:95
They both seem to be network related‽
I was seeing the same message for the stop reason in my investigations. I still don’t know how I fixed it though, it just stopped when I cleared my playlist.
This seems to be something that @elan and team might have more insights on.
Plexamp 3.9.0 is doing something similar, I’ll have to debug to find out why.
