Plexamp android save track radio playlist
Now Sonic analysis is complete. I’m loving track radio. However, there is no way to save the playlist without manually searching each track.
Would love a save now playing playlist option.
Not sure I entirely understand what you’re requesting here. If your intention is to take the play queue with you on your mobile device ‘download’ options exist on the radio stations already (via the ellipsis for each).
If that’s not what you’re after I’d suggest going to the web application and click into one of the radios you’re interested in then once the play starts expand the play queue which will offer you the ability manually add the queue to a normal playlist (top right). Then re-enter plexamp and resume listening from there at any time.
Hi, thanks for the reply.
Sorry for taking so long to reply.
I was talking about in Plexamp for Android (I added this in the wrong discussion group), there is no option once I start a track radio to save that playlist. But the workaround you gave does work so can use this.
However, the track radios are never the same twice so if it generates a brilliant playlist on Plexamp. I have to manually create this by viewing all the previous played songs.
