Plexamp auto-update on unsupported platform should not proceed
Server Version#: 1.31.3
Player Version#: 4.9.5 (just updated itself)
I run Windows 7 here. Please save the discussion about whether I should or not for another day, I have good reason to do what I am doing.
Plexamp just auto-updated itself. Since the current version is Windows 10 or above, it is now broken.
Please have the installer check to see if it is being run on a supported system before it attempts to install and breaks a working installation.
Good thing I keep backups…
fwiw, here is there error of the popup I get after the update happens:
Application popup: Plexamp.exe - Entry Point Not Found : The procedure entry point DiscardVirtualMemory could not be located in the dynamic link library KERNEL32.dll.
