I’m using Plexamp on Android headunit.
I would like add options for resumes play last played playlist.
Doesn’t Plexamp always resume with that was playing? You might need to be a bit more specific.
well, it is not.
more detailed: shows playing screen in paused state.
I checked it on a smartphone (Samsung Galaxy S20), it’s same.
- Run plexamp
- Play anything
- Terminate plexamp (on task switcher)
- Run plexamp.
it is not plays automatically. I have to tap a play button.
Ah yes, that is actually by design.
Many times, especially if it’s been a while since you’ve used the app, you would not want it loudly playing music right away.
I understand about that.
but autoplay feature (with launch) is necessary in headunit.
many legacy audio-only headunit deafult feature, too.
I wish adding this feature even it may optioned.
Is this topic not acceptable?
it’s an acceptable request ![]()
