Plexamp:Bug report Genres
Hello,
I like Plexamp it works well but i have found a bug with Genres
How to trigger it:
when you go to Genres and pick a Genre then go back and then go to the same Genre
it will have a infinte Loading Loop. happens on phone and windows.
Thanks for the great app !
Hmm, I can’t reproduce this issue. Anyone else?
Thanks for the response.
That weird but i have made a video, It happend also on pc app as well, No errors on the plex console
Video
Also it seems not only genres are affected.
Fact you can press play and it will play the genre or something else bit it will not show the albums.
I did a reinstall on the app pc and iPhone
Same result and no error on plex console and infinte loading bar.
I can reproduce this issue.
Choose Genre click on “Electronic” go back to Genre then go again to "Electronic…Loop.If you leave the menu to artist and then go to genre again it is fixed.
I can reproduce this issue as well. iPhone iOS 14.5 / PlexAmp 3.4.4
Besides for Genres, I get the same behavior with Record Labels. Choose Record Labels. Click on a record label. Go back. Click on same record label => infinite spinner…
It seems Version 3.4.5 fixes the issues for phone and windows.
Thanks ! :grin:
Buck.
