Plexamp bug
So this bug been around for a while
Go to artist page. Play popular track. Then go to an album of that artist and play it. It will not play in order. It still stores the popupr track order from that album and play it in popular order
If I understand correctly, this is a behavior which just changed. If you want to play from the album by tapping on a track, hold down menu to select Play, or play using the big :play_or_pause_button: on the album page.
Currently if you tap on a track, if the track is already in your PQ then it’ll just skip to it (new behavior).
If I’m not understanding, please help me understand what you’re doing :slight_smile:
Huh
I think you are right. And yes I noticed this change recently
