Plexamp Carplay randomly exits the "Now Playing" screen
I’m using latest server and Plexamp versions, on iPhone 13 Pro, everything up to date. My car is a 2022 Subaru Crosstrek Limited.
Very often, I will start playback on Plexamp in Carplay and without me touching my phone or any controls my my car, it exits the Now Playing screen and shows either a mostly blank screen that says only “Shuffle” on the top line (FYI, I don’t have Shuffle mode enabled in Plexamp), or it goes back to the Plexamp Home screen which shows Mixes For You, Recent Plays, Recently Added, etc. I have to click the triangle button in the top right of the screen to go back to Now Playing.
No other audio app in Carplay does this. Not Tidal, not Apple Music, not Spotify, not SiriusXM. If I put any of these apps on the Now Playing screen it stays there. Only Plexamp will randomly exit Now Playing.
Any other users seeing this? Can the developers confirm this is an issue?
never heard of this and not sure how we’d do this even if we wanted to :sweat_smile:
Upon further investigation it seems to happen when the internet connection changes between wifi and cellular. For example, when I drive away from my house and lose wifi. I’ve also had it happen when not near my home, and I don’t have my phone set to automatically connect to any public wifi. So for whatever reason Plexamp CarPlay seems super sensitive to even a split second interruption in the network.
I’ve been able to replicate it by being connected to cellular (Verizon LTE, 30Mbps) and toggling the Wifi on and off. It seems to happen whether or not the Wifi actually connected to anything.
To recap, when this happens the CarPlay screen on my dash changes from Now Plauing to either Shuffle or Home. See screenshots:
I hope you guys can fix this!
ah, i see what it’s doing, it’s not switching to shuffle, it’s switching to the Downloads tab. You just don’t have anything downloaded. It’s doing this because when it loses connectivity it can’t access the server.
Please post the logs, as it should only do that if it completely loses connectivity, not just jumps from wi-fi to lte and back.
Usually it switches from Now Playing to Home or Downloads as I pull out of the driveway and my phone switches from Wi-Fi to LTE when the Wi-Fi signal drops off (this must be a common scenario, no?), but today it did it as I was driving down the road nowhere near Wi-Fi (and my phone isn’t set to auto-connect to any public networks, or any networks other than my home). The Verizon LTE connection was 4-5 bars.
This happened around 9:11 am today so I’m including a min before and after that in the logs. The second half is in the next post. Thanks for the help!
May 12, 2023 09:10:00.083 [0x6c46f000] DEBUG - Networking: Completed request 1918: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=80122&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 103 bytes) in 100 ms.
May 12, 2023 09:10:00.085 [Javascript] INFO - ViewState: Server reports playback state progress.
May 12, 2023 09:10:05.054 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":85220,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:06.041 [0x6bc3b000] INFO - Cache: Network completed the read (810 KB/sec), awesome!
May 12, 2023 09:10:06.146 [0x6c9e7000] INFO - Cache: Asked to close file.
May 12, 2023 09:10:06.251 [0x6bc3b000] INFO - Cache: Ending network read thread.
May 12, 2023 09:10:06.252 [0x6c9e7000] INFO - Cache: Deleting file reader 0x10676c218 (2 live)
May 12, 2023 09:10:06.263 [0x6c9e7000] INFO - PQCache: Looking for 5 items ahead (total of 13) to pre-cache with network type of 1
May 12, 2023 09:10:06.263 [0x6c9e7000] INFO - PQCache: Found current item.
May 12, 2023 09:10:06.263 [0x6c9e7000] INFO - PQCache: We have 5 items successfully precached after current.
May 12, 2023 09:10:10.170 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":90319,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:15.271 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":95418,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:15.273 [Javascript] DEBUG - PlayQueue: Processing send timelines in state playing time 95418.
May 12, 2023 09:10:15.273 [Javascript] INFO - ViewState: Progress 41% (95418 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:10:15.273 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:10:15.279 [0x6bd53000] DEBUG - Networking: Create request 1919: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=95418&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:10:15.389 [0x6c46f000] DEBUG - Networking: Completed request 1919: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=95418&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 103 bytes) in 109 ms.
May 12, 2023 09:10:15.391 [Javascript] INFO - ViewState: Server reports playback state progress.
May 12, 2023 09:10:20.360 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":100516,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:25.456 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":105636,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:30.567 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":110735,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:30.569 [Javascript] DEBUG - PlayQueue: Processing send timelines in state playing time 110735.
May 12, 2023 09:10:30.569 [Javascript] INFO - ViewState: Progress 47% (110735 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:10:30.569 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:10:30.575 [0x6bbaf000] DEBUG - Networking: Create request 1920: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=110735&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:10:30.749 [0x6c46f000] DEBUG - Networking: Completed request 1920: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=110735&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 104 bytes) in 173 ms.
May 12, 2023 09:10:30.751 [Javascript] INFO - ViewState: Server reports playback state progress.
May 12, 2023 09:10:35.665 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":115834,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:40.753 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":120932,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:45.849 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":126031,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:45.851 [Javascript] DEBUG - PlayQueue: Processing send timelines in state playing time 126031.
May 12, 2023 09:10:45.851 [Javascript] INFO - ViewState: Progress 54% (126031 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:10:45.852 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:10:45.858 [0x6bddf000] DEBUG - Networking: Create request 1921: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=126031&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:10:46.499 [0x6c46f000] DEBUG - Networking: Completed request 1921: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=126031&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 100 bytes) in 640 ms.
May 12, 2023 09:10:46.501 [Javascript] INFO - ViewState: Server reports playback state complete.
May 12, 2023 09:10:50.948 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":131130,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:10:56.051 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":136228,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:01.135 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":141327,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:01.137 [Javascript] DEBUG - PlayQueue: Processing send timelines in state playing time 141327.
May 12, 2023 09:11:01.137 [Javascript] INFO - ViewState: Progress 60% (141327 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:11:01.137 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:11:01.144 [0x6bb23000] DEBUG - Networking: Create request 1922: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=141327&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:01.591 [0x6c46f000] DEBUG - Networking: Completed request 1922: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=141327&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 100 bytes) in 446 ms.
May 12, 2023 09:11:01.593 [Javascript] INFO - ViewState: Server reports playback state complete.
May 12, 2023 09:11:06.237 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":146426,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:07.984 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:11:07.984 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 2 => offline: false.
May 12, 2023 09:11:07.984 [Javascript] INFO - Companion: Network type is 2 and enabled is true.
May 12, 2023 09:11:07.984 [Javascript] INFO - PubSub: Network type is 2.
May 12, 2023 09:11:07.984 [Javascript] INFO - PubSub: Attempting to connect to pubsub, started true connected true
May 12, 2023 09:11:07.984 [Javascript] INFO - App: Network is connected, but type changed to 2, so doing preemptive connection testing on selected server.
May 12, 2023 09:11:07.984 [Javascript] INFO - DEVICE: Finding best connection for BPC Plex 3b642329e62d55b9b21b82bae1a0ae8486bf539b.
May 12, 2023 09:11:07.984 [Javascript] INFO - Discovery: Refresh based on network coming online.
May 12, 2023 09:11:07.984 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/1 server 3b642329e62d55b9b21b82bae1a0ae8486bf539b refreshing from cloud false.
May 12, 2023 09:11:07.984 [Javascript] INFO - Cloud: [RecentPlays] Syncing.
May 12, 2023 09:11:07.984 [Javascript] INFO - Mesh: Network type changed to 2.
May 12, 2023 09:11:07.984 [0x6bc3b000] DEBUG - Networking: Create request 1923: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/).
May 12, 2023 09:11:07.984 [0x6bd53000] INFO - BASS: Network switched to 2.
May 12, 2023 09:11:07.984 [0x6bd53000] INFO - Cache: Network connection upgrade (1 -> 2), so we'll restart caching.
May 12, 2023 09:11:07.984 [0x6bd53000] INFO - PQCache: Looking for 15 items ahead (total of 13) to pre-cache with network type of 2
May 12, 2023 09:11:07.984 [0x6bd53000] INFO - PQCache: Found current item.
May 12, 2023 09:11:07.984 [0x6bd53000] INFO - PQCache: We have 5 items successfully precached after current.
May 12, 2023 09:11:07.985 [0x6bc3b000] DEBUG - Networking: Create request 1924: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/).
May 12, 2023 09:11:07.986 [0x6bc3b000] DEBUG - Networking: Create request 1925: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays).
May 12, 2023 09:11:07.986 [Javascript] INFO - Companion: Attempting to start HTTP Server on port 32500.
May 12, 2023 09:11:07.988 [0x6cb8b000] DEBUG - HTTP: Serving on port 32500.
May 12, 2023 09:11:07.990 [0x6c843000] DEBUG - Networking: Create request 1926: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:07.991 [Javascript] INFO - Companion: Advertising for GDM.
May 12, 2023 09:11:07.992 [Javascript] INFO - Mesh: Attempting to connect.
May 12, 2023 09:11:07.992 [Javascript] INFO - Mesh: Testing 0 mesh players for a connection.
May 12, 2023 09:11:07.992 [Javascript] INFO - Mesh: No connection found.
May 12, 2023 09:11:07.993 [Javascript] INFO - Mesh: No connection found.
May 12, 2023 09:11:07.993 [Javascript] INFO - Companion: Listening for GDM messages.
May 12, 2023 09:11:08.004 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:11:08.012 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:11:08.016 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:11:08.016 [Javascript] INFO - Companion: Registering device 'iPhone' at 172.20.20.20:32500.
May 12, 2023 09:11:08.016 [0x6bb23000] DEBUG - Networking: Create request 1927: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:08.202 [0x6c46f000] DEBUG - Networking: Completed request 1924: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/) with code 200 (have 7824 bytes) in 217 ms.
May 12, 2023 09:11:08.204 [Javascript] INFO - DEVICE: Server connection worked for BPC Plex ~ https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140
May 12, 2023 09:11:08.204 [Javascript] INFO - DEVICE: Reading libraries and features from BPC Plex
May 12, 2023 09:11:08.204 [0x6bb23000] DEBUG - Networking: Create request 1928: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1).
May 12, 2023 09:11:08.368 [0x6c46f000] DEBUG - Networking: Completed request 1928: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1) with code 200 (have 11829 bytes) in 164 ms.
May 12, 2023 09:11:08.370 [Javascript] INFO - DEVICE: Found 3 libraries from BPC Plex: Home, Music, Playlists
May 12, 2023 09:11:08.563 [0x6c46f000] DEBUG - Networking: Completed request 1926: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 49516 bytes) in 572 ms.
May 12, 2023 09:11:08.592 [Javascript] INFO - Discovery: Setting 12 hubs from BPC Plex.
May 12, 2023 09:11:08.592 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 2 => offline: false.
May 12, 2023 09:11:08.733 [0x6bc3b000] DEBUG - Networking: Create request 1929: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&genre=13973&excludeFields=summary&id!=-1&sort=random&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:08.733 [0x6bc3b000] DEBUG - Networking: Create request 1930: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?year>=1980&year<=1989&type=9&sort=track.userRating:desc&track.userRating>=1&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:08.733 [0x6bc3b000] DEBUG - Networking: Create request 1931: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=10&sort=lastViewedAt:desc&group=guid&viewCount>=1&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:08.778 [0x6c46f000] DEBUG - Networking: Completed request 1930: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?year>=1980&year<=1989&type=9&sort=track.userRating:desc&track.userRating>=1&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 3344 bytes) in 44 ms.
May 12, 2023 09:11:08.894 [0x6c46f000] DEBUG - Networking: Completed request 1929: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&genre=13973&excludeFields=summary&id!=-1&sort=random&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 1211 bytes) in 161 ms.
May 12, 2023 09:11:08.898 [0x6c46f000] DEBUG - Networking: Completed request 1927: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone) with code 200 (have 471 bytes) in 881 ms.
May 12, 2023 09:11:08.902 [Javascript] INFO - Companion: Started HTTP Server on port 32500 and registered.
May 12, 2023 09:11:08.904 [0x6c46f000] DEBUG - Networking: Completed request 1925: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays) with code 200 (have 8783 bytes) in 918 ms.
May 12, 2023 09:11:08.915 [Javascript] INFO - Cloud: [RecentPlays] Received data, performing sync.
May 12, 2023 09:11:08.915 [Javascript] INFO - Discovery: There was a change to Recent Plays.
May 12, 2023 09:11:08.915 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 2 => offline: false.
May 12, 2023 09:11:08.987 [Javascript] INFO - Cloud: [RecentPlays] Syncing complete with added: 0 deleted: 0 and dirty: 0.
May 12, 2023 09:11:08.997 [0x6bd53000] DEBUG - Networking: Create request 1932: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/metadata/15284/children?includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:09.090 [0x6c46f000] DEBUG - Networking: Completed request 1932: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/metadata/15284/children?includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 1779 bytes) in 92 ms.
May 12, 2023 09:11:09.091 [0x6bd53000] DEBUG - Networking: Create request 1933: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/metadata/15285?includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:09.147 [0x6c46f000] DEBUG - Networking: Completed request 1931: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=10&sort=lastViewedAt:desc&group=guid&viewCount>=1&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 5343 bytes) in 413 ms.
May 12, 2023 09:11:09.190 [0x6c46f000] DEBUG - Networking: Completed request 1933: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/metadata/15285?includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 2220 bytes) in 98 ms.
May 12, 2023 09:11:09.303 [Javascript] INFO - Network changed: type is none -> OFFLINE (undefined)
May 12, 2023 09:11:09.303 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 0 => offline: true.
May 12, 2023 09:11:09.303 [Javascript] INFO - Car: Going offline for loss of network.
May 12, 2023 09:11:09.303 [0x6bbaf000] DEBUG - Car: Resetting.
May 12, 2023 09:11:09.303 [Javascript] INFO - Companion: Network type is 0 and enabled is true.
May 12, 2023 09:11:09.303 [0xf954c280] DEBUG - Car: Starting templated child item load for key ''.
May 12, 2023 09:11:09.303 [Javascript] INFO - PubSub: Network type is 0.
May 12, 2023 09:11:09.303 [Javascript] INFO - PubSub: stopping pubsub.
May 12, 2023 09:11:09.303 [Javascript] INFO - Audio Route: Network state changed to 0 so we're switching to local.
May 12, 2023 09:11:09.303 [Javascript] INFO - Discovery: Going offline.
May 12, 2023 09:11:09.303 [0x6bd53000] INFO - BASS: Network switched to 0.
May 12, 2023 09:11:09.307 [0x6c46f000] DEBUG - Networking: Cancelling request 1891.
May 12, 2023 09:11:09.307 [0x6c46f000] DEBUG - Networking: Completed request 1891: (GET https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>) with code -10000 (have 0 bytes) CANCELLED in 116089 ms.
May 12, 2023 09:11:09.335 [Javascript] INFO - Discovery: Are we offline? 0 hubs, network is 0 => offline: true.
May 12, 2023 09:11:09.345 [Javascript] INFO - Mesh: Network type changed to 0.
May 12, 2023 09:11:09.345 [Javascript] INFO - Companion: Stopping.
May 12, 2023 09:11:09.345 [Javascript] INFO - Companion: Stopping web server.
May 12, 2023 09:11:09.346 [Javascript] INFO - EventSource: Client errored with https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>
May 12, 2023 09:11:09.347 [Javascript] INFO - Car: screen requested id 5 path  key undefined limited: false image size 88.
May 12, 2023 09:11:09.370 [0xf954c280] DEBUG - Car: Starting templated child item load for key 'source=3b642329e62d55b9b21b82bae1a0ae8486bf539b&key=downloads'.
May 12, 2023 09:11:09.370 [0xf954c280] DEBUG - Car: Initial player state is playing (show: 1).
May 12, 2023 09:11:09.370 [Javascript] INFO - Car: screen requested id 6 path  key downloads limited: false image size 88.
May 12, 2023 09:11:11.326 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":151524,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:11.991 [0x6cb8b000] DEBUG - HTTP: Done serving.
May 12, 2023 09:11:11.992 [Javascript] INFO - Companion: Unregistering.
May 12, 2023 09:11:12.015 [Javascript] INFO - Companion: Registering device 'iPhone' at 172.20.20.20:32500.
May 12, 2023 09:11:12.015 [0x6bc3b000] DEBUG - Networking: Create request 1934: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:13.256 [0x6c46f000] DEBUG - Networking: Completed request 1934: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone) with code 200 (have 471 bytes) in 1240 ms.
May 12, 2023 09:11:13.257 [Javascript] INFO - Companion: Closing advertise socket.
May 12, 2023 09:11:13.257 [Javascript] INFO - Companion: Stopped.
May 12, 2023 09:11:15.401 [Javascript] INFO - Network changed: type is none -> OFFLINE (undefined)
May 12, 2023 09:11:15.401 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:11:15.401 [Javascript] INFO - Discovery: Are we offline? 0 hubs, network is 1 => offline: true.
May 12, 2023 09:11:15.401 [Javascript] INFO - Companion: Network type is 1 and enabled is true.
May 12, 2023 09:11:15.401 [Javascript] INFO - ViewState: Network came online.
May 12, 2023 09:11:15.401 [Javascript] INFO - PubSub: Network type is 1.
May 12, 2023 09:11:15.402 [Javascript] INFO - PubSub: Attempting to connect to pubsub, started false connected true
May 12, 2023 09:11:15.402 [Javascript] INFO - EventSource: Connecting to https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>
May 12, 2023 09:11:15.402 [Javascript] INFO - Audio Route: Network state changed to 1 so we're switching to local.
May 12, 2023 09:11:15.402 [Javascript] INFO - App: Network is connected, but type changed to 1, so doing preemptive connection testing on selected server.
May 12, 2023 09:11:15.402 [Javascript] INFO - DEVICE: Finding best connection for BPC Plex 3b642329e62d55b9b21b82bae1a0ae8486bf539b.
May 12, 2023 09:11:15.402 [Javascript] INFO - Discovery: Refresh based on network coming online.
May 12, 2023 09:11:15.402 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/1 server 3b642329e62d55b9b21b82bae1a0ae8486bf539b refreshing from cloud false.
May 12, 2023 09:11:15.402 [0x6bb23000] DEBUG - Networking: Create request 1935: (GET https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>).
May 12, 2023 09:11:15.402 [0x6c9e7000] INFO - BASS: Network switched to 1.
May 12, 2023 09:11:15.402 [0x6c9e7000] INFO - Cache: Network connection upgrade (0 -> 1), so we'll restart caching.
May 12, 2023 09:11:15.402 [0x6bb23000] DEBUG - Networking: Create request 1936: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/).
May 12, 2023 09:11:15.403 [0x6bb23000] DEBUG - Networking: Create request 1937: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/).
May 12, 2023 09:11:15.404 [Javascript] INFO - Cloud: [RecentPlays] Syncing.
May 12, 2023 09:11:15.404 [Javascript] INFO - Mesh: Network type changed to 1.
May 12, 2023 09:11:15.404 [Javascript] INFO - METRICS: Attempting to flush 10 events.
May 12, 2023 09:11:15.404 [0x6caff000] DEBUG - Networking: Create request 1938: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays).
May 12, 2023 09:11:15.405 [0x6caff000] DEBUG - Networking: Create request 1939: (POST https://analytics.plex.tv/collect/event).
May 12, 2023 09:11:15.410 [0x6bc3b000] DEBUG - Networking: Create request 1940: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:15.545 [0x6c46f000] DEBUG - Networking: Completed request 1937: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/) with code 200 (have 7824 bytes) in 141 ms.
May 12, 2023 09:11:15.548 [Javascript] INFO - DEVICE: Server connection worked for BPC Plex ~ https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140
May 12, 2023 09:11:15.548 [Javascript] INFO - DEVICE: Reading libraries and features from BPC Plex
May 12, 2023 09:11:15.548 [0x6bc3b000] DEBUG - Networking: Create request 1941: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1).
May 12, 2023 09:11:15.828 [0x6c46f000] DEBUG - Networking: Completed request 1941: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1) with code 200 (have 11829 bytes) in 279 ms.
May 12, 2023 09:11:15.831 [Javascript] INFO - DEVICE: Found 3 libraries from BPC Plex: Home, Music, Playlists
May 12, 2023 09:11:15.968 [0x6c46f000] DEBUG - Networking: Completed request 1940: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 49516 bytes) in 557 ms.
May 12, 2023 09:11:16.000 [Javascript] INFO - Discovery: Setting 12 hubs from BPC Plex.
May 12, 2023 09:11:16.000 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 1 => offline: false.
May 12, 2023 09:11:16.000 [Javascript] INFO - Car: We have network now, and home screen loaded.
May 12, 2023 09:11:16.000 [Javascript] INFO - Cloud: [SharedItems] Syncing.
May 12, 2023 09:11:16.000 [0x6c9e7000] DEBUG - Car: Resetting.
May 12, 2023 09:11:16.000 [0x6c9e7000] DEBUG - Networking: Create request 1942: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=SharedItems).
May 12, 2023 09:11:16.000 [0xf954c280] DEBUG - Car: Starting templated child item load for key ''.
May 12, 2023 09:11:16.092 [Javascript] INFO - Car: screen requested id 7 path  key undefined limited: false image size 88.
May 12, 2023 09:11:16.101 [0xf954c280] DEBUG - Car: Starting templated child item load for key 'source=3b642329e62d55b9b21b82bae1a0ae8486bf539b&key=home-hubs'.
May 12, 2023 09:11:16.101 [0xf954c280] DEBUG - Car: Starting templated child item load for key 'source=3b642329e62d55b9b21b82bae1a0ae8486bf539b&key=artist-letters'.
May 12, 2023 09:11:16.101 [0xf954c280] DEBUG - Car: Starting templated child item load for key 'source=3b642329e62d55b9b21b82bae1a0ae8486bf539b&key=charts'.
May 12, 2023 09:11:16.101 [0xf954c280] DEBUG - Car: Initial player state is playing (show: 1).
May 12, 2023 09:11:16.106 [Javascript] INFO - Car: screen requested id 8 path  key home-hubs limited: false image size 88.
May 12, 2023 09:11:16.106 [Javascript] INFO - Car: screen requested id 9 path  key artist-letters limited: false image size 88.
May 12, 2023 09:11:16.107 [Javascript] INFO - Car: screen requested id 10 path  key charts limited: false image size 88.
May 12, 2023 09:11:16.111 [0x6caff000] DEBUG - Networking: Create request 1943: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&genre=13973&excludeFields=summary&id!=-1&sort=random&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:16.114 [0x6caff000] DEBUG - Networking: Create request 1944: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/firstCharacter?includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:16.114 [0x6caff000] DEBUG - Networking: Create request 1945: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/playlists/all?type=15&playlistType=audio&sort=lastViewedAt:desc&sectionID=1&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:16.114 [0x6caff000] DEBUG - Networking: Create request 1946: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&sort=addedAt:desc&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:16.239 [0x6c46f000] DEBUG - Networking: Completed request 1943: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&genre=13973&excludeFields=summary&id!=-1&sort=random&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 1211 bytes) in 127 ms.
May 12, 2023 09:11:16.412 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":156623,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:16.414 [Javascript] DEBUG - PlayQueue: Processing send timelines in state playing time 156623.
May 12, 2023 09:11:16.414 [Javascript] INFO - ViewState: Progress 67% (156623 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:11:16.414 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:11:16.420 [0x6c9e7000] DEBUG - Networking: Create request 1947: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=156623&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:16.535 [0x6c46f000] DEBUG - Networking: Completed request 1947: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=156623&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 100 bytes) in 114 ms.
May 12, 2023 09:11:16.537 [Javascript] INFO - ViewState: Server reports playback state complete.
May 12, 2023 09:11:16.702 [0x6c46f000] DEBUG - Networking: Completed request 1938: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays) with code 200 (have 8783 bytes) in 1297 ms.
May 12, 2023 09:11:16.713 [Javascript] INFO - Cloud: [RecentPlays] Received data, performing sync.
May 12, 2023 09:11:16.713 [Javascript] INFO - Discovery: There was a change to Recent Plays.
May 12, 2023 09:11:16.727 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 1 => offline: false.
May 12, 2023 09:11:16.776 [Javascript] INFO - Cloud: [RecentPlays] Syncing complete with added: 0 deleted: 0 and dirty: 0.
May 12, 2023 09:11:16.783 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:11:16.941 [0x6c46f000] DEBUG - Networking: Completed request 1942: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=SharedItems) with code 404 (have 105 bytes) in 940 ms.
May 12, 2023 09:11:16.943 [Javascript] INFO - Cloud: [SharedItems] Error getting data: HTTP status 404
May 12, 2023 09:11:16.943 [Javascript] INFO - Cloud: [SharedItems] Received data, performing sync.
May 12, 2023 09:11:16.943 [Javascript] INFO - Cloud: [SharedItems] Syncing complete with added: 0 deleted: 0 and dirty: 0.
May 12, 2023 09:11:17.453 [0x6c46f000] DEBUG - Networking: Completed request 1944: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/firstCharacter?includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 1642 bytes) in 1338 ms.
May 12, 2023 09:11:17.454 [0x6c46f000] DEBUG - Networking: Completed request 1945: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/playlists/all?type=15&playlistType=audio&sort=lastViewedAt:desc&sectionID=1&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 2476 bytes) in 1339 ms.
May 12, 2023 09:11:18.842 [0x6c46f000] DEBUG - Networking: Completed request 1939: (POST https://analytics.plex.tv/collect/event) with code -7 (have 0 bytes) in 3437 ms.
May 12, 2023 09:11:18.843 [Javascript] WARNING - METRICS: Error sending event:, HTTP status -7
May 12, 2023 09:11:21.518 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":161722,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:22.989 [0x6c46f000] DEBUG - Networking: Completed request 1923: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/) with code -28 (have 0 bytes) in 15004 ms.
May 12, 2023 09:11:22.991 [Javascript] WARNING - DEVICE: Server connection https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400 didn't work for BPC Plex: HTTP status -28
May 12, 2023 09:11:23.422 [0x6c46f000] DEBUG - Networking: Completed request 1946: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&sort=addedAt:desc&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 184403 bytes) in 7307 ms.
May 12, 2023 09:11:26.052 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:11:26.052 [Javascript] INFO - Network changed: type is none -> OFFLINE (undefined)
May 12, 2023 09:11:26.052 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 0 => offline: true.
May 12, 2023 09:11:26.052 [Javascript] INFO - Car: Going offline for loss of network.
May 12, 2023 09:11:26.052 [Javascript] INFO - Companion: Network type is 0 and enabled is true.
May 12, 2023 09:11:26.052 [Javascript] INFO - PubSub: Network type is 0.
May 12, 2023 09:11:26.052 [Javascript] INFO - PubSub: stopping pubsub.
May 12, 2023 09:11:26.052 [0x6caff000] DEBUG - Car: Resetting.
May 12, 2023 09:11:26.052 [0xf954c280] DEBUG - Car: Starting templated child item load for key ''.
May 12, 2023 09:11:26.052 [Javascript] INFO - Audio Route: Network state changed to 0 so we're switching to local.
May 12, 2023 09:11:26.052 [Javascript] INFO - Discovery: Going offline.
May 12, 2023 09:11:26.053 [0x6bd53000] INFO - BASS: Network switched to 0.
May 12, 2023 09:11:26.061 [0x6c46f000] DEBUG - Networking: Cancelling request 1935.
May 12, 2023 09:11:26.061 [0x6c46f000] DEBUG - Networking: Completed request 1935: (GET https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>) with code -10000 (have 0 bytes) CANCELLED in 10658 ms.
May 12, 2023 09:11:26.074 [Javascript] INFO - Discovery: Are we offline? 0 hubs, network is 0 => offline: true.
May 12, 2023 09:11:26.080 [Javascript] INFO - Mesh: Network type changed to 0.
May 12, 2023 09:11:26.081 [Javascript] INFO - Car: screen requested id 11 path  key undefined limited: false image size 88.
May 12, 2023 09:11:26.083 [0xf954c280] DEBUG - Car: Starting templated child item load for key 'source=3b642329e62d55b9b21b82bae1a0ae8486bf539b&key=downloads'.
May 12, 2023 09:11:26.083 [0xf954c280] DEBUG - Car: Initial player state is playing (show: 1).
May 12, 2023 09:11:26.084 [Javascript] INFO - EventSource: Client errored with https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>
May 12, 2023 09:11:26.087 [Javascript] INFO - Car: screen requested id 12 path  key downloads limited: false image size 88.
May 12, 2023 09:11:26.607 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":166820,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:30.415 [0x6c46f000] DEBUG - Networking: Completed request 1936: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/) with code -28 (have 0 bytes) in 15012 ms.
May 12, 2023 09:11:30.416 [Javascript] WARNING - DEVICE: Server connection https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400 didn't work for BPC Plex: HTTP status -28
May 12, 2023 09:11:31.697 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":171834,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:31.699 [Javascript] DEBUG - PlayQueue: Processing send timelines in state playing time 171834.
May 12, 2023 09:11:31.699 [Javascript] INFO - ViewState: Progress 73% (171834 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:11:31.699 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:11:31.706 [0x6bb23000] DEBUG - Networking: Create request 1948: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=171834&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:32.370 [0x6c46f000] DEBUG - Networking: Completed request 1948: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=171834&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 100 bytes) in 664 ms.
May 12, 2023 09:11:32.371 [Javascript] INFO - ViewState: Server reports playback state complete.
May 12, 2023 09:11:36.787 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":176932,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:36.815 [Javascript] INFO - Network changed: type is none -> OFFLINE (undefined)
May 12, 2023 09:11:36.815 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:11:36.815 [Javascript] INFO - Discovery: Are we offline? 0 hubs, network is 1 => offline: true.
May 12, 2023 09:11:36.815 [Javascript] INFO - Companion: Network type is 1 and enabled is true.
May 12, 2023 09:11:36.815 [Javascript] INFO - ViewState: Network came online.
May 12, 2023 09:11:36.815 [Javascript] INFO - PubSub: Network type is 1.
May 12, 2023 09:11:36.815 [Javascript] INFO - PubSub: Attempting to connect to pubsub, started false connected true
May 12, 2023 09:11:36.815 [Javascript] INFO - EventSource: Connecting to https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>
May 12, 2023 09:11:36.815 [Javascript] INFO - Audio Route: Network state changed to 1 so we're switching to local.
May 12, 2023 09:11:36.815 [Javascript] INFO - App: Network is connected, but type changed to 1, so doing preemptive connection testing on selected server.
May 12, 2023 09:11:36.815 [Javascript] INFO - DEVICE: Finding best connection for BPC Plex 3b642329e62d55b9b21b82bae1a0ae8486bf539b.
May 12, 2023 09:11:36.815 [Javascript] INFO - Discovery: Refresh based on network coming online.
May 12, 2023 09:11:36.815 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/1 server 3b642329e62d55b9b21b82bae1a0ae8486bf539b refreshing from cloud false.
May 12, 2023 09:11:36.815 [0x6bc3b000] DEBUG - Networking: Create request 1949: (GET https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>).
May 12, 2023 09:11:36.816 [0x6bb23000] INFO - BASS: Network switched to 1.
May 12, 2023 09:11:36.816 [0x6bb23000] INFO - Cache: Network connection upgrade (0 -> 1), so we'll restart caching.
May 12, 2023 09:11:36.816 [0x6bc3b000] DEBUG - Networking: Create request 1950: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/).
May 12, 2023 09:11:36.816 [0x6bc3b000] DEBUG - Networking: Create request 1951: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/).
May 12, 2023 09:11:36.817 [0x6bbaf000] DEBUG - Networking: Create request 1952: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays).
May 12, 2023 09:11:36.817 [Javascript] INFO - Cloud: [RecentPlays] Syncing.
May 12, 2023 09:11:36.817 [Javascript] INFO - Mesh: Network type changed to 1.
May 12, 2023 09:11:36.818 [Javascript] INFO - METRICS: Attempting to flush 10 events.
May 12, 2023 09:11:36.818 [0x6bbaf000] DEBUG - Networking: Create request 1953: (POST https://analytics.plex.tv/collect/event).
May 12, 2023 09:11:36.823 [0x6bddf000] DEBUG - Networking: Create request 1954: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:36.824 [0x6c46f000] DEBUG - Networking: Completed request 1953: (POST https://analytics.plex.tv/collect/event) with code -7 (have 0 bytes) in 6 ms.
May 12, 2023 09:11:36.824 [Javascript] WARNING - METRICS: Error sending event:, HTTP status -7
May 12, 2023 09:11:36.916 [0x6c46f000] DEBUG - Networking: Completed request 1951: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/) with code 200 (have 7824 bytes) in 99 ms.
May 12, 2023 09:11:36.918 [Javascript] INFO - DEVICE: Server connection worked for BPC Plex ~ https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140
May 12, 2023 09:11:36.918 [Javascript] INFO - DEVICE: Reading libraries and features from BPC Plex
May 12, 2023 09:11:36.918 [0x6bc3b000] DEBUG - Networking: Create request 1955: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1).
May 12, 2023 09:11:37.073 [0x6c46f000] DEBUG - Networking: Completed request 1955: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1) with code 200 (have 11829 bytes) in 154 ms.
May 12, 2023 09:11:37.076 [Javascript] INFO - DEVICE: Found 3 libraries from BPC Plex: Home, Music, Playlists
May 12, 2023 09:11:37.461 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:11:41.896 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":182031,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:46.990 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":187130,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:46.992 [Javascript] DEBUG - PlayQueue: Processing send timelines in state playing time 187130.
May 12, 2023 09:11:46.992 [Javascript] INFO - ViewState: Progress 80% (187130 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:11:46.992 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:11:46.999 [0x6bddf000] DEBUG - Networking: Create request 1956: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=187130&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:47.401 [0x6c46f000] DEBUG - Networking: Completed request 1956: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=187130&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 100 bytes) in 401 ms.
May 12, 2023 09:11:47.403 [Javascript] INFO - ViewState: Server reports playback state complete.
May 12, 2023 09:11:51.826 [0x6c46f000] DEBUG - Networking: Completed request 1950: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/) with code -28 (have 0 bytes) in 15010 ms.
May 12, 2023 09:11:51.828 [Javascript] WARNING - DEVICE: Server connection https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400 didn't work for BPC Plex: HTTP status -28
May 12, 2023 09:11:52.094 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":192228,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:56.940 [Javascript] INFO - DEVICE: Persisting devices because BPC Plex was dirty.
May 12, 2023 09:11:56.940 [Javascript] INFO - DEVICE: Persisting 3 devices.
May 12, 2023 09:11:56.940 [Javascript] INFO - LRUCache: We have 2053 nodes, asked to limit to 2048.
May 12, 2023 09:11:56.940 [Javascript] INFO - LRUCache: Pruning 5 nodes from Images.
May 12, 2023 09:11:56.942 [0x6bddf000] DEBUG - Networking: Create request 1957: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/:/eventsource/notifications?filters=timeline&X-Plex-Token=<token>).
May 12, 2023 09:11:56.942 [Javascript] INFO - EventSource: Cancelling 1903 to https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/:/eventsource/notifications?filters=timeline&X-Plex-Token=<token>
May 12, 2023 09:11:56.942 [Javascript] INFO - EventSource: Connecting to https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/:/eventsource/notifications?filters=timeline&X-Plex-Token=<token>
May 12, 2023 09:11:56.942 [Javascript] INFO - LRUCache: We have 257 nodes, asked to limit to 256.
May 12, 2023 09:11:56.942 [Javascript] INFO - LRUCache: Pruning 1 nodes from AlbumCodec.
May 12, 2023 09:11:56.943 [Javascript] INFO - Memory usage: 68.0 MB Native: 157.9 MB
May 12, 2023 09:11:57.186 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":197327,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:58.637 [0xf954c280] INFO - Audio Session: Interruption started (suspended: 0, resume: 0).
May 12, 2023 09:11:58.637 [0xf954c280] DEBUG - BASS: Audio interruption started (playing).
May 12, 2023 09:11:58.637 [0xf954c280] INFO - BASS: Pause.
May 12, 2023 09:11:58.637 [0xf954c280] INFO - BASS: Pausing stream 51104 with fade, kill: 0
May 12, 2023 09:11:58.637 [0x6cfeb000] INFO - Audio Route: Keeping a note of when we last paused.
May 12, 2023 09:11:58.653 [Javascript] INFO - Audio: State changed from playing to paused.
May 12, 2023 09:11:58.653 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"paused","time":198756,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:11:58.653 [Javascript] INFO - Player: State transition playing -> paused for source local ID 51104.
May 12, 2023 09:11:58.662 [Javascript] DEBUG - PlayQueue: Processing send timelines in state paused time 198756.
May 12, 2023 09:11:58.662 [Javascript] INFO - ViewState: Progress 85% (198756 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:11:58.662 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:11:58.663 [Javascript] INFO - Player: Sending state changed [A] Television - Ain't That Nothin' (Remastered Single Version) (198756/232453) in state paused with artwork true.
May 12, 2023 09:11:58.664 [0x6bbaf000] DEBUG - Networking: Create request 1958: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=paused&duration=232453&time=198756&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:11:58.664 [0x6bb23000] DEBUG - Audio Session: Set state info for state paused.
May 12, 2023 09:11:58.664 [0x6bb23000] DEBUG - Audio Session: Processing poster change (exists: 1)
May 12, 2023 09:11:58.665 [0x6bb23000] DEBUG - Audio Session: Processing metadata change (playing: 1 — Television / Ain't That Nothin' (Remastered Single Version))
May 12, 2023 09:11:58.665 [0xf954c280] DEBUG - Car: Got state paused.
May 12, 2023 09:11:58.665 [0xf954c280] DEBUG - Car: Configuring Now Playing buttons (long form: 0 playing: 1)
May 12, 2023 09:11:58.765 [0x6c46f000] DEBUG - Networking: Completed request 1958: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=paused&duration=232453&time=198756&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 100 bytes) in 101 ms.
May 12, 2023 09:11:58.767 [Javascript] INFO - ViewState: Server reports playback state complete.
May 12, 2023 09:11:58.893 [0xf954c280] INFO - Audio Route: Audio route is now CarPlay (port type is CarAudio)
May 12, 2023 09:11:58.893 [0xf954c280] INFO - Audio Route: Duh, we already knew we were on CarAudio, ignoring.
May 12, 2023 09:11:58.894 [Javascript] INFO - Audio Route: Local route changed to CarPlay (CarAudio)
May 12, 2023 09:11:58.894 [0xf954c280] INFO - Audio Route: Audio route is now CarPlay (port type is CarAudio)
May 12, 2023 09:11:58.894 [0xf954c280] DEBUG - BASS: Audio route changed to CarPlay (CarAudio).
May 12, 2023 09:11:58.941 [0x6d103000] INFO - BASS: Stream 51104 is paused.
May 12, 2023 09:11:59.546 [0x6d103000] INFO - BASS: Pausing audio output (after delay: 1)
May 12, 2023 09:11:59.546 [0x6d103000] INFO - BASS: Suspending player.
May 12, 2023 09:11:59.547 [0x6d103000] INFO - BASS: Setting audio session active to 0.
May 12, 2023 09:12:02.878 [0x6bd53000] INFO - BASS: Network switched to 2.
May 12, 2023 09:12:02.878 [0x6bd53000] INFO - Cache: Network connection upgrade (1 -> 2), so we'll restart caching.
May 12, 2023 09:12:02.878 [0x6bd53000] INFO - PQCache: Looking for 15 items ahead (total of 13) to pre-cache with network type of 2
May 12, 2023 09:12:02.878 [0x6bd53000] INFO - PQCache: Found current item.
May 12, 2023 09:12:02.878 [0x6bd53000] INFO - PQCache: We have 5 items successfully precached after current.
May 12, 2023 09:12:02.878 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:02.878 [Javascript] INFO - Discovery: Are we offline? 0 hubs, network is 2 => offline: true.
May 12, 2023 09:12:02.878 [Javascript] INFO - Companion: Network type is 2 and enabled is true.
May 12, 2023 09:12:02.879 [Javascript] INFO - PubSub: Network type is 2.
May 12, 2023 09:12:02.879 [Javascript] INFO - PubSub: Attempting to connect to pubsub, started true connected true
May 12, 2023 09:12:02.879 [Javascript] INFO - App: Network is connected, but type changed to 2, so doing preemptive connection testing on selected server.
May 12, 2023 09:12:02.879 [Javascript] INFO - DEVICE: Finding best connection for BPC Plex 3b642329e62d55b9b21b82bae1a0ae8486bf539b.
May 12, 2023 09:12:02.879 [Javascript] INFO - Discovery: Refresh based on network coming online.
May 12, 2023 09:12:02.879 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/1 server 3b642329e62d55b9b21b82bae1a0ae8486bf539b refreshing from cloud false.
May 12, 2023 09:12:02.879 [Javascript] INFO - Mesh: Network type changed to 2.
May 12, 2023 09:12:02.879 [0x6bb23000] DEBUG - Networking: Create request 1959: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/).
May 12, 2023 09:12:02.880 [Javascript] INFO - Companion: Attempting to start HTTP Server on port 32500.
May 12, 2023 09:12:02.881 [0x6bb23000] DEBUG - Networking: Create request 1960: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/).
May 12, 2023 09:12:02.881 [0x6bb23000] DEBUG - Networking: Create request 1961: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:02.884 [Javascript] INFO - Mesh: Attempting to connect.
May 12, 2023 09:12:02.884 [Javascript] INFO - Mesh: Testing 0 mesh players for a connection.
May 12, 2023 09:12:02.884 [Javascript] INFO - Mesh: No connection found.
May 12, 2023 09:12:02.884 [0x6caff000] DEBUG - HTTP: Serving on port 32500.
May 12, 2023 09:12:02.885 [Javascript] INFO - Companion: Advertising for GDM.
May 12, 2023 09:12:02.885 [Javascript] INFO - Companion: Listening for GDM messages.
May 12, 2023 09:12:02.896 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:02.902 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:02.906 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:02.906 [Javascript] INFO - Companion: Registering device 'iPhone' at 172.20.20.20:32500.
May 12, 2023 09:12:02.906 [0x6bddf000] DEBUG - Networking: Create request 1962: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:02.966 [0x6c46f000] DEBUG - Networking: Completed request 1960: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/) with code 200 (have 7824 bytes) in 84 ms.
May 12, 2023 09:12:02.967 [Javascript] INFO - DEVICE: Server connection worked for BPC Plex ~ https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140
May 12, 2023 09:12:02.967 [Javascript] INFO - DEVICE: Reading libraries and features from BPC Plex
May 12, 2023 09:12:02.967 [0x6c843000] DEBUG - Networking: Create request 1963: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1).
May 12, 2023 09:12:03.126 [0x6c46f000] DEBUG - Networking: Completed request 1963: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1) with code 200 (have 11829 bytes) in 159 ms.
May 12, 2023 09:12:03.128 [Javascript] INFO - DEVICE: Found 3 libraries from BPC Plex: Home, Music, Playlists
May 12, 2023 09:12:03.760 [0x6c46f000] DEBUG - Networking: Completed request 1962: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone) with code 200 (have 471 bytes) in 853 ms.
May 12, 2023 09:12:03.761 [Javascript] INFO - Companion: Started HTTP Server on port 32500 and registered.
May 12, 2023 09:12:04.298 [Javascript] INFO - Network changed: type is none -> OFFLINE (undefined)
May 12, 2023 09:12:04.298 [Javascript] INFO - Discovery: Are we offline? 0 hubs, network is 0 => offline: true.
May 12, 2023 09:12:04.298 [Javascript] INFO - Companion: Network type is 0 and enabled is true.
May 12, 2023 09:12:04.298 [Javascript] INFO - PubSub: Network type is 0.
May 12, 2023 09:12:04.298 [Javascript] INFO - PubSub: stopping pubsub.
May 12, 2023 09:12:04.298 [Javascript] INFO - Audio Route: Network state changed to 0 so we're switching to local.
May 12, 2023 09:12:04.298 [Javascript] INFO - Discovery: Going offline.
May 12, 2023 09:12:04.298 [0x6c843000] INFO - BASS: Network switched to 0.
May 12, 2023 09:12:04.299 [0x6c46f000] DEBUG - Networking: Cancelling request 1949.
May 12, 2023 09:12:04.299 [0x6c46f000] DEBUG - Networking: Completed request 1949: (GET https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>) with code -10000 (have 0 bytes) CANCELLED in 27483 ms.
May 12, 2023 09:12:04.305 [Javascript] INFO - Discovery: Are we offline? 0 hubs, network is 0 => offline: true.
May 12, 2023 09:12:04.305 [Javascript] INFO - Mesh: Network type changed to 0.
May 12, 2023 09:12:04.305 [Javascript] INFO - Companion: Stopping.
May 12, 2023 09:12:04.305 [Javascript] INFO - Companion: Stopping web server.
May 12, 2023 09:12:04.306 [Javascript] INFO - EventSource: Client errored with https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>
May 12, 2023 09:12:06.829 [0x6c46f000] DEBUG - Networking: Completed request 1952: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays) with code -28 (have 0 bytes) in 30011 ms.
May 12, 2023 09:12:06.829 [0x6c46f000] DEBUG - Networking: Completed request 1954: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code -28 (have 0 bytes) in 30006 ms.
May 12, 2023 09:12:06.830 [Javascript] INFO - Cloud: [RecentPlays] Error getting data: HTTP status -28
May 12, 2023 09:12:06.830 [Javascript] WARNING - Cloud: [RecentPlays] No cloud data.
May 12, 2023 09:12:06.830 [Javascript] INFO - Cloud: [RecentPlays] Syncing complete with added: 0 deleted: 0 and dirty: 0.
May 12, 2023 09:12:06.831 [Javascript] INFO - Error loading: get https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone: HTTP status -28
May 12, 2023 09:12:06.831 [Javascript] INFO - DEVICE: Finding best connection for BPC Plex 3b642329e62d55b9b21b82bae1a0ae8486bf539b.
May 12, 2023 09:12:06.831 [0x6bd53000] DEBUG - Networking: Create request 1964: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/).
May 12, 2023 09:12:06.831 [0x6bd53000] DEBUG - Networking: Create request 1965: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/).
May 12, 2023 09:12:06.832 [0x6c46f000] DEBUG - Networking: Completed request 1964: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/) with code -7 (have 0 bytes) in 0 ms.
May 12, 2023 09:12:06.832 [Javascript] WARNING - DEVICE: Server connection https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400 didn't work for BPC Plex: HTTP status -7
May 12, 2023 09:12:06.888 [0x6caff000] DEBUG - HTTP: Done serving.
May 12, 2023 09:12:06.889 [Javascript] INFO - Companion: Unregistering.
May 12, 2023 09:12:06.915 [Javascript] INFO - Companion: Registering device 'iPhone' at 172.20.20.20:32500.
May 12, 2023 09:12:06.915 [0x6bc3b000] DEBUG - Networking: Create request 1966: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:07.360 [0x6c46f000] DEBUG - Networking: Completed request 1965: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/) with code 200 (have 7824 bytes) in 528 ms.
May 12, 2023 09:12:07.361 [Javascript] INFO - DEVICE: Server connection worked for BPC Plex ~ https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140
May 12, 2023 09:12:07.361 [Javascript] INFO - DEVICE: Reading libraries and features from BPC Plex
May 12, 2023 09:12:07.361 [0x6bddf000] DEBUG - Networking: Create request 1967: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1).
May 12, 2023 09:12:07.613 [0x6c46f000] DEBUG - Networking: Completed request 1966: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone) with code 200 (have 471 bytes) in 697 ms.
May 12, 2023 09:12:07.615 [Javascript] INFO - Companion: Closing advertise socket.
May 12, 2023 09:12:07.615 [Javascript] INFO - Companion: Stopped.
May 12, 2023 09:12:08.020 [0x6c46f000] DEBUG - Networking: Completed request 1967: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1) with code 200 (have 11829 bytes) in 658 ms.
May 12, 2023 09:12:08.021 [Javascript] INFO - DEVICE: Found 3 libraries from BPC Plex: Home, Music, Playlists
May 12, 2023 09:12:08.022 [0x6bd53000] DEBUG - Networking: Create request 1968: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:10.490 [0x6c46f000] DEBUG - Networking: Completed request 1968: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 49516 bytes) in 2467 ms.
May 12, 2023 09:12:10.503 [Javascript] INFO - Another new request came in, tossing data (looking for: 11, was: 12)
May 12, 2023 09:12:12.662 [0x6bddf000] INFO - BASS: Network switched to 2.
May 12, 2023 09:12:12.662 [0x6bddf000] INFO - Cache: Network connection upgrade (0 -> 2), so we'll restart caching.
May 12, 2023 09:12:12.662 [0x6bddf000] INFO - PQCache: Looking for 15 items ahead (total of 13) to pre-cache with network type of 2
May 12, 2023 09:12:12.662 [0x6bddf000] INFO - PQCache: Found current item.
May 12, 2023 09:12:12.662 [0x6bddf000] INFO - PQCache: We have 5 items successfully precached after current.
May 12, 2023 09:12:12.663 [0x6bddf000] DEBUG - Networking: Create request 1969: (GET https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>).
May 12, 2023 09:12:12.663 [Javascript] INFO - Network changed: type is none -> OFFLINE (undefined)
May 12, 2023 09:12:12.663 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:12.663 [Javascript] INFO - Discovery: Are we offline? 0 hubs, network is 2 => offline: true.
May 12, 2023 09:12:12.663 [Javascript] INFO - Companion: Network type is 2 and enabled is true.
May 12, 2023 09:12:12.663 [Javascript] INFO - ViewState: Network came online.
May 12, 2023 09:12:12.663 [0x6bddf000] DEBUG - Networking: Create request 1970: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/).
May 12, 2023 09:12:12.663 [Javascript] INFO - PubSub: Network type is 2.
May 12, 2023 09:12:12.663 [Javascript] INFO - PubSub: Attempting to connect to pubsub, started false connected true
May 12, 2023 09:12:12.663 [Javascript] INFO - EventSource: Connecting to https://pubsub.plex.tv/sub/eventsource/182851699/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?X-Plex-Token=<token>
May 12, 2023 09:12:12.663 [Javascript] INFO - App: Network is connected, but type changed to 2, so doing preemptive connection testing on selected server.
May 12, 2023 09:12:12.663 [Javascript] INFO - DEVICE: Finding best connection for BPC Plex 3b642329e62d55b9b21b82bae1a0ae8486bf539b.
May 12, 2023 09:12:12.663 [Javascript] INFO - Discovery: Refresh based on network coming online.
May 12, 2023 09:12:12.663 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/1 server 3b642329e62d55b9b21b82bae1a0ae8486bf539b refreshing from cloud false.
May 12, 2023 09:12:12.664 [0x6bddf000] DEBUG - Networking: Create request 1971: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/).
May 12, 2023 09:12:12.664 [Javascript] INFO - Cloud: [RecentPlays] Syncing.
May 12, 2023 09:12:12.664 [Javascript] INFO - Mesh: Network type changed to 2.
May 12, 2023 09:12:12.664 [Javascript] INFO - METRICS: Attempting to flush 10 events.
May 12, 2023 09:12:12.665 [0x6bc3b000] DEBUG - Networking: Create request 1972: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays).
May 12, 2023 09:12:12.665 [0x6bc3b000] DEBUG - Networking: Create request 1973: (POST https://analytics.plex.tv/collect/event).
May 12, 2023 09:12:12.665 [Javascript] INFO - Companion: Attempting to start HTTP Server on port 32500.
May 12, 2023 09:12:12.667 [Javascript] INFO - Mesh: Attempting to connect.
May 12, 2023 09:12:12.668 [Javascript] INFO - Mesh: Testing 0 mesh players for a connection.
May 12, 2023 09:12:12.668 [Javascript] INFO - Mesh: No connection found.
May 12, 2023 09:12:12.668 [Javascript] INFO - Mesh: Attempting to connect.
May 12, 2023 09:12:12.668 [0x6bddf000] DEBUG - Networking: Create request 1974: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:12.671 [0x6c843000] DEBUG - HTTP: Serving on port 32500.
May 12, 2023 09:12:12.672 [Javascript] INFO - Companion: Advertising for GDM.
May 12, 2023 09:12:12.673 [Javascript] INFO - Companion: Listening for GDM messages.
May 12, 2023 09:12:12.675 [0x6c46f000] DEBUG - Networking: Completed request 1973: (POST https://analytics.plex.tv/collect/event) with code -7 (have 0 bytes) in 10 ms.
May 12, 2023 09:12:12.675 [Javascript] WARNING - METRICS: Error sending event:, HTTP status -7
May 12, 2023 09:12:12.685 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:12.690 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:12.695 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:12.695 [Javascript] INFO - Companion: Registering device 'iPhone' at 172.20.20.20:32500.
May 12, 2023 09:12:12.696 [0x6bbaf000] DEBUG - Networking: Create request 1975: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:12.905 [0x6c46f000] DEBUG - Networking: Completed request 1972: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays) with code 200 (have 8783 bytes) in 240 ms.
May 12, 2023 09:12:12.913 [Javascript] INFO - Cloud: [RecentPlays] Received data, performing sync.
May 12, 2023 09:12:12.913 [Javascript] INFO - Discovery: There was a change to Recent Plays.
May 12, 2023 09:12:12.913 [Javascript] INFO - Cloud: [RecentPlays] Syncing complete with added: 0 deleted: 0 and dirty: 0.
May 12, 2023 09:12:13.697 [0x6c46f000] DEBUG - Networking: Completed request 1974: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 49516 bytes) in 1029 ms.
May 12, 2023 09:12:13.734 [Javascript] INFO - Discovery: Setting 12 hubs from BPC Plex.
May 12, 2023 09:12:13.734 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 2 => offline: false.
May 12, 2023 09:12:13.734 [Javascript] INFO - Car: We have network now, and home screen loaded.
May 12, 2023 09:12:13.734 [Javascript] INFO - Cloud: [SharedItems] Syncing.
May 12, 2023 09:12:13.734 [Javascript] INFO - Cloud: [RecentPlays] Syncing.
May 12, 2023 09:12:13.734 [0x6c9e7000] DEBUG - Car: Resetting.
May 12, 2023 09:12:13.734 [0x6bc3b000] DEBUG - Networking: Create request 1976: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=SharedItems).
May 12, 2023 09:12:13.734 [0xf954c280] DEBUG - Car: Starting templated child item load for key ''.
May 12, 2023 09:12:13.734 [0x6bc3b000] DEBUG - Networking: Create request 1977: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays).
May 12, 2023 09:12:13.825 [Javascript] INFO - Car: screen requested id 13 path  key undefined limited: false image size 88.
May 12, 2023 09:12:13.828 [0xf954c280] DEBUG - Car: Starting templated child item load for key 'source=3b642329e62d55b9b21b82bae1a0ae8486bf539b&key=home-hubs'.
May 12, 2023 09:12:13.828 [0xf954c280] DEBUG - Car: Starting templated child item load for key 'source=3b642329e62d55b9b21b82bae1a0ae8486bf539b&key=artist-letters'.
May 12, 2023 09:12:13.828 [0xf954c280] DEBUG - Car: Starting templated child item load for key 'source=3b642329e62d55b9b21b82bae1a0ae8486bf539b&key=charts'.
May 12, 2023 09:12:13.828 [0xf954c280] DEBUG - Car: Initial player state is paused (show: 1).
May 12, 2023 09:12:13.828 [0xf954c280] DEBUG - Car: We'd like to activate audio session, other playing: 1.
May 12, 2023 09:12:13.828 [0xf954c280] DEBUG - Car: Configuring Now Playing buttons (long form: 0 playing: 1)
May 12, 2023 09:12:13.839 [Javascript] INFO - Car: screen requested id 14 path  key home-hubs limited: false image size 88.
May 12, 2023 09:12:13.839 [Javascript] INFO - Car: screen requested id 15 path  key artist-letters limited: false image size 88.
May 12, 2023 09:12:13.849 [Javascript] INFO - Car: screen requested id 16 path  key charts limited: false image size 88.
May 12, 2023 09:12:13.849 [0x6bbaf000] DEBUG - Networking: Create request 1978: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&genre=13973&excludeFields=summary&id!=-1&sort=random&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:13.853 [0x6c9e7000] DEBUG - Networking: Create request 1979: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/firstCharacter?includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:13.854 [0x6c9e7000] DEBUG - Networking: Create request 1980: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&sort=addedAt:desc&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:13.854 [0x6c9e7000] DEBUG - Networking: Create request 1981: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/playlists/all?type=15&playlistType=audio&sort=lastViewedAt:desc&sectionID=1&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:13.950 [Javascript] DEBUG - PlayQueue: Processing send timelines in state paused time 198756.
May 12, 2023 09:12:13.950 [Javascript] INFO - ViewState: Progress 85% (198756 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:12:13.950 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:12:13.950 [0x6cb8b000] DEBUG - Networking: Create request 1982: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=paused&duration=232453&time=198756&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:14.055 [0x6c46f000] DEBUG - Networking: Completed request 1978: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&genre=13973&excludeFields=summary&id!=-1&sort=random&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 1211 bytes) in 205 ms.
May 12, 2023 09:12:14.205 [0x6c46f000] DEBUG - Networking: Completed request 1976: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=SharedItems) with code 404 (have 105 bytes) in 470 ms.
May 12, 2023 09:12:14.208 [Javascript] INFO - Cloud: [SharedItems] Error getting data: HTTP status 404
May 12, 2023 09:12:14.208 [Javascript] INFO - Cloud: [SharedItems] Received data, performing sync.
May 12, 2023 09:12:14.208 [Javascript] INFO - Cloud: [SharedItems] Syncing complete with added: 0 deleted: 0 and dirty: 0.
May 12, 2023 09:12:14.769 [0x6c46f000] DEBUG - Networking: Completed request 1979: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/firstCharacter?includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 1642 bytes) in 915 ms.
May 12, 2023 09:12:14.982 [0xf954c280] INFO - Audio Route: Audio route is now CarPlay (port type is CarAudio)
May 12, 2023 09:12:14.982 [0xf954c280] INFO - Audio Route: Duh, we already knew we were on CarAudio, ignoring.
May 12, 2023 09:12:14.983 [0xf954c280] INFO - Audio Route: Audio route is now CarPlay (port type is CarAudio)
May 12, 2023 09:12:14.983 [0xf954c280] DEBUG - BASS: Audio route changed to CarPlay (CarAudio).
May 12, 2023 09:12:14.983 [Javascript] INFO - Audio Route: Local route changed to CarPlay (CarAudio)
May 12, 2023 09:12:14.987 [0xf954c280] INFO - Audio Session: Interruption ended (suspended: 0, resume: 1).
May 12, 2023 09:12:14.987 [0xf954c280] DEBUG - BASS: Audio interruption ended, should resume (idle).
May 12, 2023 09:12:14.987 [0xf954c280] INFO - BASS: Resume.
May 12, 2023 09:12:14.987 [0xf954c280] DEBUG - BASS: Ensuring we're not idle.
May 12, 2023 09:12:14.989 [0xf954c280] INFO - BASS: Setting audio session active to 1.
May 12, 2023 09:12:14.989 [0xf954c280] DEBUG - BASS: Resetting device (soft: 1, force: 0, initialized: 1).
May 12, 2023 09:12:15.046 [0xf954c280] DEBUG - BASS: Suspending device (sample rate: 44100, num channels: 2, soft: 1, decode only: 0, force: 0)
May 12, 2023 09:12:15.046 [0xf954c280] DEBUG - BASS: We have 0 dying streams which we're going to kill immediately.
May 12, 2023 09:12:15.046 [0xf954c280] INFO - BASS: We're overlapping stream 51230 (0x80000428) by 7765 ms which is in 25.9 sec.
May 12, 2023 09:12:15.046 [0xf954c280] DEBUG - BASS: Processing stream (pause: 0, delay: 25.9 sec).
May 12, 2023 09:12:15.046 [0xf954c280] INFO - Cache: Asked to seek to offset 5990 with read buffer offset at 278528.
May 12, 2023 09:12:15.046 [0xf954c280] INFO - Cache: Yay, seek was inside read buffer.
May 12, 2023 09:12:15.047 [0xf954c280] INFO - BASS: Resuming audio output (started: 1)
May 12, 2023 09:12:15.047 [0xf954c280] DEBUG - BASS: Sliding volume to 100.0 over 0 ms.
May 12, 2023 09:12:15.054 [0xf954c280] INFO - BASS: Setting audio session active to 1.
May 12, 2023 09:12:15.054 [0xf954c280] INFO - BASS: We're overlapping stream 51230 (0x80000428) by 7765 ms which is in 25.9 sec.
May 12, 2023 09:12:15.054 [0xf954c280] DEBUG - BASS: Processing stream (pause: 0, delay: 25.9 sec).
May 12, 2023 09:12:15.054 [0xf954c280] INFO - Cache: Asked to seek to offset 5990 with read buffer offset at 278528.
May 12, 2023 09:12:15.054 [0xf954c280] INFO - Cache: Yay, seek was inside read buffer.
May 12, 2023 09:12:15.056 [0xf954c280] DEBUG - BASS: Fading in stream.
May 12, 2023 09:12:15.056 [0xf954c280] INFO - BASS: Resuming with fade.
May 12, 2023 09:12:15.056 [0xf954c280] DEBUG - BASS: Sliding volume to 100.0 over 300 ms.
May 12, 2023 09:12:15.056 [0xf954c280] DEBUG - BASS: Taking mixer pause flag off channel.
May 12, 2023 09:12:15.056 [0xf954c280] DEBUG - BASS: Resumed in 69 ms.
May 12, 2023 09:12:15.062 [Javascript] INFO - Audio: State changed from paused to playing.
May 12, 2023 09:12:15.062 [Javascript] INFO - PlayQueue: Saving state {"source":"3b642329e62d55b9b21b82bae1a0ae8486bf539b","state":"playing","time":198756,"rate":1,"repeat":0,"volume":0,"playQueueID":"867","playQueueVersion":15,"playQueueItemID":"51104"}
May 12, 2023 09:12:15.062 [Javascript] INFO - Player: State transition paused -> playing for source local ID 51104.
May 12, 2023 09:12:15.064 [Javascript] DEBUG - PlayQueue: Processing send timelines in state playing time 198756.
May 12, 2023 09:12:15.064 [Javascript] INFO - ViewState: Progress 85% (198756 ms) on item 3b642329e62d55b9b21b82bae1a0ae8486bf539b/15307.
May 12, 2023 09:12:15.064 [Javascript] INFO - ViewState: Trying to send directly.
May 12, 2023 09:12:15.065 [0x6bc3b000] DEBUG - Audio Session: Set state info for state playing.
May 12, 2023 09:12:15.065 [Javascript] INFO - Player: Sending state changed [A] Television - Ain't That Nothin' (Remastered Single Version) (198756/232453) in state playing with artwork true.
May 12, 2023 09:12:15.065 [0xf954c280] DEBUG - Car: Got state playing.
May 12, 2023 09:12:15.066 [0x6bddf000] DEBUG - Networking: Create request 1983: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=198756&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:15.071 [0x6c46f000] DEBUG - Networking: Completed request 1982: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=paused&duration=232453&time=198756&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 100 bytes) in 1121 ms.
May 12, 2023 09:12:15.072 [Javascript] INFO - ViewState: Server reports playback state complete.
May 12, 2023 09:12:15.112 [0x6c46f000] DEBUG - Networking: Completed request 1983: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/:/timeline?state=playing&duration=232453&time=198756&playQueueItemID=51104&key=%2Flibrary%2Fmetadata%2F15307&ratingKey=15307&playQueueID=867&playQueueVersion=15&containerKey=%2FplayQueues%2F867&hasMDE=1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 100 bytes) in 46 ms.
May 12, 2023 09:12:15.113 [Javascript] INFO - ViewState: Server reports playback state complete.
May 12, 2023 09:12:15.225 [0x6c46f000] DEBUG - Networking: Completed request 1975: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone) with code 200 (have 471 bytes) in 2529 ms.
May 12, 2023 09:12:15.225 [0x6c46f000] DEBUG - Networking: Completed request 1980: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/library/sections/1/all?type=9&sort=addedAt:desc&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 184403 bytes) in 1370 ms.
May 12, 2023 09:12:15.225 [Javascript] INFO - Companion: Started HTTP Server on port 32500 and registered.
May 12, 2023 09:12:15.307 [0x6c46f000] DEBUG - Networking: Completed request 1981: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/playlists/all?type=15&playlistType=audio&sort=lastViewedAt:desc&sectionID=1&excludeFields=summary&id!=-1&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 2476 bytes) in 1453 ms.
May 12, 2023 09:12:15.856 [0x6c46f000] DEBUG - Networking: Completed request 1977: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays) with code 200 (have 8783 bytes) in 2121 ms.
May 12, 2023 09:12:15.872 [Javascript] INFO - Cloud: [RecentPlays] Received data, performing sync.
May 12, 2023 09:12:15.872 [Javascript] INFO - Discovery: There was a change to Recent Plays.
May 12, 2023 09:12:15.872 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 2 => offline: false.
May 12, 2023 09:12:15.935 [Javascript] INFO - Cloud: [RecentPlays] Syncing complete with added: 0 deleted: 0 and dirty: 0.
May 12, 2023 09:12:17.888 [0x6c46f000] DEBUG - Networking: Completed request 1959: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/) with code -28 (have 0 bytes) in 15008 ms.
May 12, 2023 09:12:17.890 [Javascript] WARNING - DEVICE: Server connection https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400 didn't work for BPC Plex: HTTP status -28
May 12, 2023 09:12:18.981 [0x6c46f000] DEBUG - Networking: Completed request 1971: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/) with code 200 (have 7824 bytes) in 6317 ms.
May 12, 2023 09:12:18.983 [Javascript] INFO - DEVICE: Server connection worked for BPC Plex ~ https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140
May 12, 2023 09:12:18.983 [Javascript] INFO - DEVICE: Reading libraries and features from BPC Plex
May 12, 2023 09:12:18.983 [0x6bddf000] DEBUG - Networking: Create request 1984: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1).
May 12, 2023 09:12:19.151 [0x6c46f000] DEBUG - Networking: Completed request 1984: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1) with code 200 (have 11829 bytes) in 167 ms.
May 12, 2023 09:12:19.153 [Javascript] INFO - DEVICE: Found 3 libraries from BPC Plex: Home, Music, Playlists
May 12, 2023 09:12:19.666 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:19.666 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:12:19.666 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 1 => offline: false.
May 12, 2023 09:12:19.666 [Javascript] INFO - Companion: Network type is 1 and enabled is true.
May 12, 2023 09:12:19.666 [Javascript] INFO - PubSub: Network type is 1.
May 12, 2023 09:12:19.666 [Javascript] INFO - PubSub: Attempting to connect to pubsub, started true connected true
May 12, 2023 09:12:19.666 [Javascript] INFO - Audio Route: Network state changed to 1 so we're switching to local.
May 12, 2023 09:12:19.666 [Javascript] INFO - App: Network is connected, but type changed to 1, so doing preemptive connection testing on selected server.
May 12, 2023 09:12:19.666 [Javascript] INFO - DEVICE: Finding best connection for BPC Plex 3b642329e62d55b9b21b82bae1a0ae8486bf539b.
May 12, 2023 09:12:19.666 [Javascript] INFO - Discovery: Refresh based on network coming online.
May 12, 2023 09:12:19.666 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/1 server 3b642329e62d55b9b21b82bae1a0ae8486bf539b refreshing from cloud false.
May 12, 2023 09:12:19.666 [Javascript] INFO - Cloud: [RecentPlays] Syncing.
May 12, 2023 09:12:19.666 [Javascript] INFO - Mesh: Network type changed to 1.
May 12, 2023 09:12:19.666 [Javascript] INFO - Companion: Stopping.
May 12, 2023 09:12:19.666 [Javascript] INFO - Companion: Stopping web server.
May 12, 2023 09:12:19.667 [0x6caff000] DEBUG - Networking: Create request 1985: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/).
May 12, 2023 09:12:19.667 [0x6bc3b000] INFO - BASS: Network switched to 1.
May 12, 2023 09:12:19.668 [0x6caff000] DEBUG - Networking: Create request 1986: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/).
May 12, 2023 09:12:19.668 [0x6caff000] DEBUG - Networking: Create request 1987: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays).
May 12, 2023 09:12:19.674 [0x6bddf000] DEBUG - Networking: Create request 1988: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:19.761 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:12:19.804 [0x6c46f000] DEBUG - Networking: Completed request 1961: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 49516 bytes) in 16923 ms.
May 12, 2023 09:12:19.825 [Javascript] INFO - Another new request came in, tossing data (looking for: 12, was: 14)
May 12, 2023 09:12:20.199 [0x6c46f000] DEBUG - Networking: Completed request 1986: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/) with code 200 (have 7824 bytes) in 531 ms.
May 12, 2023 09:12:20.201 [Javascript] INFO - DEVICE: Server connection worked for BPC Plex ~ https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140
May 12, 2023 09:12:20.201 [Javascript] INFO - DEVICE: Reading libraries and features from BPC Plex
May 12, 2023 09:12:20.201 [0x6bddf000] DEBUG - Networking: Create request 1989: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1).
May 12, 2023 09:12:20.374 [0x6c46f000] DEBUG - Networking: Completed request 1989: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1) with code 200 (have 11829 bytes) in 172 ms.
May 12, 2023 09:12:20.376 [Javascript] INFO - DEVICE: Found 3 libraries from BPC Plex: Home, Music, Playlists
May 12, 2023 09:12:20.676 [0x6c843000] DEBUG - HTTP: Done serving.
May 12, 2023 09:12:20.677 [Javascript] INFO - Companion: Unregistering.
May 12, 2023 09:12:20.689 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:12:20.706 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:12:20.706 [0x6bb23000] DEBUG - Networking: Create request 1990: (PUT https://plex.tv/devices/07d65fe7-53ec-4aff-9489-4ea3f4f272c9?Connection[][uri]=http://172.20.20.20:32500&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:20.706 [Javascript] INFO - Companion: Registering device 'iPhone' at 172.20.20.20:32500.
May 12, 2023 09:12:20.766 [Javascript] INFO - Network changed: type is cellular -> CELLULAR (undefined)
May 12, 2023 09:12:21.546 [0x6c46f000] DEBUG - Networking: Completed request 1987: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays) with code 200 (have 8783 bytes) in 1877 ms.
May 12, 2023 09:12:21.552 [Javascript] INFO - Cloud: [RecentPlays] Received data, performing sync.
May 12, 2023 09:12:21.557 [Javascript] INFO - Discovery: There was a change to Recent Plays.
May 12, 2023 09:12:21.572 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 1 => offline: false.
May 12, 2023 09:12:21.626 [Javascript] INFO - Cloud: [RecentPlays] Syncing complete with added: 0 deleted: 0 and dirty: 0.
May 12, 2023 09:12:23.680 [Javascript] INFO - Network changed: type is wifi -> WIFI (undefined)
May 12, 2023 09:12:23.680 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 2 => offline: false.
May 12, 2023 09:12:23.680 [Javascript] INFO - Companion: Network type is 2 and enabled is true.
May 12, 2023 09:12:23.680 [Javascript] INFO - PubSub: Network type is 2.
May 12, 2023 09:12:23.680 [Javascript] INFO - PubSub: Attempting to connect to pubsub, started true connected true
May 12, 2023 09:12:23.680 [Javascript] INFO - App: Network is connected, but type changed to 2, so doing preemptive connection testing on selected server.
May 12, 2023 09:12:23.680 [Javascript] INFO - DEVICE: Finding best connection for BPC Plex 3b642329e62d55b9b21b82bae1a0ae8486bf539b.
May 12, 2023 09:12:23.680 [Javascript] INFO - Discovery: Refresh based on network coming online.
May 12, 2023 09:12:23.680 [0x6cc17000] INFO - BASS: Network switched to 2.
May 12, 2023 09:12:23.680 [Javascript] INFO - Discovery: Fetching hubs for library /library/sections/1 server 3b642329e62d55b9b21b82bae1a0ae8486bf539b refreshing from cloud false.
May 12, 2023 09:12:23.680 [0x6cc17000] INFO - Cache: Network connection upgrade (1 -> 2), so we'll restart caching.
May 12, 2023 09:12:23.680 [Javascript] INFO - Cloud: [RecentPlays] Syncing.
May 12, 2023 09:12:23.680 [0x6cc17000] INFO - PQCache: Looking for 15 items ahead (total of 13) to pre-cache with network type of 2
May 12, 2023 09:12:23.680 [0x6cc17000] INFO - PQCache: Found current item.
May 12, 2023 09:12:23.680 [Javascript] INFO - Mesh: Network type changed to 2.
May 12, 2023 09:12:23.680 [0x6cc17000] INFO - PQCache: We have 5 items successfully precached after current.
May 12, 2023 09:12:23.681 [0x6c9e7000] DEBUG - Networking: Create request 1991: (GET https://192-168-0-214.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:32400/).
May 12, 2023 09:12:23.682 [0x6c9e7000] DEBUG - Networking: Create request 1992: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/).
May 12, 2023 09:12:23.682 [0x6c9e7000] DEBUG - Networking: Create request 1993: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays).
May 12, 2023 09:12:23.682 [Javascript] INFO - Mesh: Attempting to connect.
May 12, 2023 09:12:23.682 [Javascript] INFO - Mesh: Testing 0 mesh players for a connection.
May 12, 2023 09:12:23.682 [Javascript] INFO - Mesh: No connection found.
May 12, 2023 09:12:23.683 [0x6caff000] DEBUG - Networking: Create request 1994: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone).
May 12, 2023 09:12:23.782 [0x6c46f000] DEBUG - Networking: Completed request 1994: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/hubs/sections/1?count=4&includeExternalMetadata=1&includeMyMixes=1&includeAnniversaryReleases=1&excludeElements=Similar,Mood&includeLibraryPlaylists=1&includeStations=1&includeStationDirectories=1&excludeFields=summary&includeFields=thumbBlurHash&X-Plex-Device-Name=iPhone) with code 200 (have 49516 bytes) in 98 ms.
May 12, 2023 09:12:23.814 [0x6c46f000] DEBUG - Networking: Completed request 1992: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/) with code 200 (have 7824 bytes) in 132 ms.
May 12, 2023 09:12:23.818 [Javascript] INFO - Discovery: Setting 12 hubs from BPC Plex.
May 12, 2023 09:12:23.818 [Javascript] INFO - Discovery: Are we offline? 11 hubs, network is 2 => offline: false.
May 12, 2023 09:12:23.867 [Javascript] INFO - DEVICE: Server connection worked for BPC Plex ~ https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140
May 12, 2023 09:12:23.867 [Javascript] INFO - DEVICE: Reading libraries and features from BPC Plex
May 12, 2023 09:12:23.868 [0x6cc17000] DEBUG - Networking: Create request 1995: (GET https://98-60-66-88.e2e11a05a580432ba349aa2a9dba62d1.plex.direct:22140/media/providers?includePreferences=1).
May 12, 2023 09:12:23.955 [0x6c46f000] DEBUG - Networking: Completed request 1993: (GET https://plex.tv/api/v2/user/settings?uuid=ecd9489c641d7cb7&key=RecentPlays) with code 200 (have 8783 bytes) in 272 ms.
Any solution?
Help please?
Sorry, as far as I know this is somewhat “normal” behavior when Internet connectivity glitches on your phone. Apple’s guidelines say that the app should adjust the menus when connectivity is lost and restored.
Thanks for the reply.
I would think it’s possible to program Plexamp such that the connectivity must be lost for some reasonable amount of time before anything happens? Like… 5 seconds? Because it’s only losing the connection for 1 second or less, and none of my other audio apps do anything when the phone transitions from WiFi to cellular (not Spotify, XM, Tidal, Apple Music…).
TBH, it’s really quite annoying for Plexamp to switch Carplay away from the Now Playing screen automatically for any reason at all. There must be some relatively straightforward way for you to prevent this?
The same happens to me. The ‘now playing’ screen disappears randomly and other screens appear. I never have playback disruptions so in my view this should not happen if cellular is briefly interrupted. Could this please be fixed?
Seems like this won’t be fixed. I don’t know why Plex thinks it’s a good idea to automatically switch away from the Now Playing screen for any reason whatsoever. It’s bad UX, and no other audio app that I’ve ever used on my iPhone does this. If I’m on the Now Playing screen, I want it to stay there, regardless of whether my network connection glitches out for a split second. If the music stops playing because the networked is borked, I’ll take action myself.
Don’t assume that. CarPlay specifically tells developers to react to changes in connectivity.
It’s not “for any reason”, it’s “for loss of internet connectivity”.
We’ll see if we can make this less jarring.
Thanks for the further insight. I think if you guys just program it to wait 10 seconds before determining that connectivity is actually lost, that would fix it. As it is, it seems like it freaks out if the connection is lost for less than 1 second while I pull out of my driveway and my phone loses the WiFi signal and switches to cellular. Or if for whatever reason my cellular connection drops for a few seconds before picking up another tower.
I’ve tried to think about it from your point of view as the developer, but I just don’t see how it makes sense to switch away from the Now Playing screen unless Plexamp has actually run out of buffered music to play (IIRC, it buffers several minutes worth of playback at all times, no?). In my mind, it should only interrupt me if the network is truly down for a significant amount of time AND it’s run out of music in the buffer.
You act like we’re purposefully doing it. We’re not.
We’re telling CarPlay to use a new menu structure for offline, which has the unfortunate side effect of popping out of Now Playing. Blame the primitive CarPlay API :laughing:
Thanks for the reactions! For countries where mobile phone coverage is not perfect, this is really a bit of a pain. Just had it again on my way back from holidays. It would be great if you can program this differently :slight_smile:
On other streaming apps, e.g. TuneIn Radio, I think it just “pauses” when out of connectivity/buffer. Buffer seems to be not a real issue for PlexAmp so somehow ignoring this loss of connectivity until buffer runs out could be “simple”. Maybe just showing a kind of warning icon?
Maybe related, maybe not (I will read again other related posts). After a certain duration of driving and playing (random duration), the music playback gets distorted (like a cracking) - regularly… The only solution I have is to shut down Plexamp and relaunch. But this is not a really healthy option while driving… Hope this will get investigated.
Maybe the easiest solution for this is for Plexamp to automatically go back to the Now Playing screen once connectivity is restored? Surely that’s as easy to code as the code that switches it away from the Now Playing when it loses connectivity?
Please don’t assume things are easy to code :sweat_smile: We’ll figure something out.
