Plexamp - distortion on one device same settings
Server Version#: 1.32.7.7571
Player Version#: plexamp 4.8
I have 2 iPhones an X and a 14 pro max. the settings within plexamp are the same.
  • equalizer on
  • pre-amp +4 (default)
  • Equalizer preamp gain +3
  • Audio output = strict
  • loudness leveling on
when playing with the 14 pro max audio is great audio on the X is 100% distorted. Had to move the equalizer pre amp gain to -3 to even it out. happens both bluetooth and wired.
how can I resolve the issue? I want the x to use same settings as 14 pro max.
set that to 0 dB
Different hardware may require different settings.
Another thought. Check your volume settings on the iphones. Does one Iphone have a max volume limit set? And the other is maxed out?
