Plexamp downloading over cellular
So far I’m loving the Plexamp for Android. I do wish you would increase the size of a downloadable playlist to more than the 24hr limit though.
But anyways, I’ve noticed that Plexamp continues to download files over cellular even if the setting is turned off. Is this a bug?
i just tested this… seems like a bug.
see elans response about the 24h limit here:
Do you mean it continued to download when you switched to cellular, or that when on cellular, you were able to kick off a download even though the setting was turned off? The latter is intended as a bit of a manual override, but we’ll be looking to add a confirmation.
I started the download on wifi at home, then I left for a walk and noticed that it was continuing to download on cellular. I switched off my cellular data and it stopped downloading. As soon as I switch my cellular data back on it reconnected and started to continue the download.
Was your setting set to disable cellular downloads? If so, please reproduce and DM me the app log.
