Installed plexamp and when I launch it - I see a brown box that shows recently added info only. When I use the search and try to play something - it constantly crashes (and fills up the console logs.
Here’s what it “looks like” is happening(from the console log):
- AMFI: There is a null code directory pointer. This is an unexpected condition.
- kernel: proc 893: load code signature error 4 for file “mpd”
- com.apple.xpc.launchd: (com.apple.ReportCrash[894]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
- com.apple.xpc.launchd: (tv.plex.plexamp.155948[818]) Service exited due to signal: Killed: 9
- ReportCrash: Saved crasp report for mpd[893] version 0 to . . .
- ReportCrash: Removing excessive log:
The above repeats every 4 or 5 seconds.
Steps to replicate:
- download Plexamp-1.0.0.dmg file and double click on it
- Slide plexamp onto “applications”
- Launch plexamp by double-clicking plexamp icon in application directory
Note: Rebooting after install does not have any effect.
