Plexamp Flatpak/AppImage - Does not start playback until audio device switched
I’ve started experiencing a weird issue with the Plexamp flatpak on Linux recently. Basically when I launch the app and first try to play a song, there’s no audio output and the playback seekbar will keep skipping backwards/forwards by 1 second.
The only way I can fix this is to go into the settings and change the audio device and then back to Pulseaudio, but I have to do this every time I open the app. I’ve had this happen on two different Linux desktops, one Debian 12 and the other Debian 13. No other applications besides Plexamp have any issues like this. I cleared out its data folder under ~/.var, and that fixed it exactly one time, but then after closing/reopening the app it starts doing it again.
I’m getting the same behavior with the latest AppImage too.
When I downgrade from 4.12.4 to 4.12.3 I no longer have the issue.
Also reported to GitHub for posterity: 4.12.3 - Does not start playback until audio device switched · Issue #270 · flathub/com.plexamp.Plexamp · GitHub
Having same problem on fedora 42
Ditto, Debian 13.
yep Linux Mint as well
I also confirmed this on Manjaro with PipeWire.
I tested the AppImage and Flatpak, and found the same problem.
Linux Mint 22.2, can confirm the issue and the workaround to change audio device.
Can we get some acknowledgement from Plex about this issue, given that this seems to affect a large group of Linux users? I’m happy to help test any potential fixes.
Appears to be fixed in 4.13.0. I had to switch it back and forth one last time but it seems to stick now. Thanks to whoever at Plex fixed the bug.
Where are you seeing 4.13.0 available? Discover Store still has 4.12.4 as the latest.
Correction: I still have the issue again after a reboot so it looks like it’s not fixed yet, and 4.13.0 may have been pulled from flathub. If anyone at Plex is reading this and working on it, I’m happy to help test a potential fix before it’s released.
Can confirm. Issue still here.
I think the cache simply reset itself on the first launch after 4.13.0 upgrade.
I had the impression that it worked well more than once, but now I have the problem every time I launch it.
Besides, I have the problem on Gnome or KDE, so it’s probably related to PipeWire/PA.
@trankillity: The Flatpak image has not been updated, only the AppImage on the Plex website.
having the same issue with version 4.13. quite annoying. downgrade to 4.12.3 seems to help, but as the app always updates itself it’s not even a permanent workaround.
Ditto, still having this same issue.
I’m also seeing this on 4.12.4.
In case it matters, my system has pipewire 1.4.9
Same here. Using the latest Appimage.
still waiting for a fix.
Hey,
Problem related https://forums.plex.tv/t/plexamp-headless-playback-stuck-bouncing-at-00-01-forever/
I have the same issue. For me I was thinking it was some sort of audio device initialization issue since it seemed to happen mostly on first boot or after screen blanking.
Curious that some have reported rolling back to an earlier version as solving it.
@elan Any chance of a fix please?
Will look into it; a fair bit of stuff changed between the two versions under the hood.
