Plexamp for Linux does not work at all
I just found out there’s Plexamp for Linux and downloaded the flatpak and installed it and it just doesn’t do anything, it’s just an icon with a yellow marking and Plasma warning it’s running in the background.
Edit: Plexamp for Linux does not work at all. The Flatpak just fails as described previously:
Launching from terminal outputs:
Wayland socket is available, running natively on Wayland.
To disable, remove the --socket=wayland permission.
Passing the following arguments to Electron: --enable-gpu-rasterization --enable-zero-copy --enable-gpu-compositing --enable-native-gpu-memory-buffers --enable-oop-rasterization --disable-gpu-blocklist --ozone-platform=wayland --enable-features=UseSkiaRenderer
[3:0113/105951.306469:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
amdgpu: unknown (family_id, chip_external_rev): (145, 32)
LaunchProcess: failed to execvp:
xdg-settings
[3:0113/105951.506004:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[3:0113/105951.506037:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
Main: restoring window state from /home/user/.var/app/com.plexamp.Plexamp/config/Plexamp/window-state-plexamp-main.json
Started Media Service: false
libEGL warning: DRI2: failed to create dri screen
Linux: Registering MPRIS service.
[45:0113/105951.571427:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
[110:0113/105951.641471:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
[54:0113/105951.684465:ERROR:command_buffer_proxy_impl.cc(127)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
[3:0113/105952.165248:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[3:0113/105952.165278:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[3:0113/105952.165308:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[3:0113/105952.165328:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[3:0113/105952.165346:ERROR:bus.cc(407)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
APPIMAGE env is not defined, current application is not an AppImage
Couldn’t install shortcut for Command+Alt+Up.
Couldn’t install shortcut for Command+Alt+Down.
Couldn’t install shortcut for MediaPlayPause.
Couldn’t install shortcut for MediaPreviousTrack.
Couldn’t install shortcut for MediaNextTrack.
Couldn’t install shortcut for MediaStop.
Warning: vkCreateInstance: Found no drivers!
Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
Using the Appimage produces a login window that crashes the application the moment that you authenticate with your Plex account details:
Main: restoring window state from /home/user/.config/Plexamp/window-state-plexamp-main.json
Checking for update
[12917:0114/131405.351199:ERROR:nss_util.cc(357)] After loading Root Certs, loaded==false: NSS error code: -8018
Update for version 4.9.5 is not available (latest version: 4.9.5, downgrade is disallowed).
checkForUpdatesAndNotify called, downloadPromise is null
[12976:0114/131408.537235:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
[12976:0114/131410.987293:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
[12976:0114/131436.399044:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
Error: Render process (Plexamp) crashed (139) :frowning:
Quitting…
I’m running:
openSUSE Tumbleweed 6.6.6-1-default #1 SMP PREEMPT_DYNAMIC Mon Dec 11 09:46:39 UTC 2023 (a946a9f) x86_64 x86_64 x86_64 GNU/Linux
DE: Plasma 5.27.10
WM: kwin
Wayland session.
Also, Plexamp uses org.freedesktop.Platform 21.08.
Runtime org.freedesktop.Platform.GL.default branch 21.08 is end-of-life.
