Plexamp on OpenSuSE Tumbleweed?
Server Version#: Version 4.81.1 from PlexMediaServer-1.26.2.5797-5bd057d2b-x86_64.qpkg
Player Version#: Plexamp-4.2.1.AppImage
PMS is running on QNAP TVS-872XT
PlexAmp works on Android phone and on Windows. I can’t get it to even start on Linux, which is my primary desktop OS.
After having set executable permissions on the AppImage, trying to run it by clicking the file appears to do nothing. Advanced Permissions shows X for Owner, Owning Group, and Others.
From konsole, I have tried this:
./Plexamp-4.2.1.AppImage
Gtk-Message: 13:10:19.941: Failed to load module “appmenu-gtk-module”
Main: Window state x:undefined y:undefined w:270 h:515 fullscreen:undefined maximized:undefined
Main: Display bounds x:undefined y:undefined w:undefined h:undefined
Started Media Service: false
Linux: Registering MPRIS service.
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[5979:0523/131020.649754:FATAL:gpu_data_manager_impl_private.cc(415)] GPU process isn’t usable. Goodbye.
Trace/breakpoint trap (core dumped)
Why doesn’t it work?
From YaST2 I found and installed:
appmenu-gtk-module-common
appmenu-gtk2-module
appmenu-gtk3-module
[10652:0523/161626.330935:FATAL:gpu_data_manager_impl_private.cc(415)] GPU process isn’t usable. Goodbye.
Searching for help on the errors has not helped. Any ideas?
I have also installed these along with all their dependencies:
appmenu-gtk2-module-debuginfo
appmenu-gtk3-module-debuginfo
libappmenu-gtk-parser-deve
libappmenu-gtk2-parser-devel
libappmenu-gtk2-parser0-debuginfo
libappmenu-gtk3-parser-devel
libappmenu-gtk3-parser0-debuginfo
No change.
Try adding “–disable-gpu-sandbox” when you run plexamp.
