Plexamp for raspberry pi - plans for newer node versions?
Node 12 is past end of life … can Plex devs share their plans for making Plexamp (on the Pi) work with node 14, 16, etc.?
I’m sure we’ll update it at some point, but our main scenario right now is hw dedicated to headless, so having a slightly outdated node does’t seem like the end of the world :sweat_smile:
Thanks, makes sense I guess.
The question occurred to me as I was trying to add Plexamp to an audio-specific distribution that’s 64 bit and already switched to node 14 … most others that I’m aware of are either 32 bit only still (too bad, no Plexamp for them), or are 64 bit and built on the same Raspberry Pi OS that I’m already using.
I’m not sure what audio distribution this is, but we generally are using plain raspbian or armbian here atm.
It was RoPieee (I think it is/was arch based) … I got it to work using nvm without obviously breaking anything else, but I think it would have disappeared at the next update (everything gets replaced except some settings … it’s not meant to be tinkered with)
