Plexamp on the Raspberry Pi
(Making this a pinned thread until we have better instructions/links on the website.)
OK, ready to have some fun?
  1. Make sure you have a 64-bit capable Raspberry Pi and node v16 installed.
  2. Download the headless package from https://plexamp.com
  3. Extract in the pi home directory.
  4. Run from terminal to start (and ignore anything which is printed after you enter the code):
$ node js/index.js
Starting Plexamp.
Please visit https://plex.tv/claim and enter the claim token:
  1. You should now be able to hit http://<ip.of.pi>:32500 from a browser and get the Plexamp UI (you’ll need to sign in again in the browser, otherwise it would be a security risk). When you change player/cache settings, you’re changing the Pi settings. When you change UI settings, you’re changing app/browser settings. Play some music! Or control it from any other instance of Plexamp. (The browser portion was mostly for free and seemed cool and useful, but there are definitely things to fix up in there.)
  2. Install the Plexamp service if you feel like having it start on boot (and why wouldn’t you?). CTRL-C out of the foreground running Plexamp and do this:
$ sudo cp plexamp.service /lib/systemd/system/
$ sudo systemctl daemon-reload
$ sudo systemctl enable plexamp
$ sudo systemctl start plexamp
Congratulations, you’re now running the latest and most advanced version of Plexamp on your Pi! :sun_with_face: If you’re into Hi-Res audio, make sure to enable sample rate matching, and pretend you can hear the difference.
As I think I said before, I’ve only tested with a PiFi Digi+ board, which you can get super cheaply online, e.g. here. This provides optical/digital outputs, which is what I was looking for. I’ve additionally made some tweaks so that it’s the default audio output.
Pro tip: edit the plexamp.service file to add a working directory line, otherwise, Ultrablur won’t work in the browser.
[Service]
Type=simple
User=pi
WorkingDirectory=/home/pi/plexamp
ExecStart=/usr/bin/node /home/pi/plexamp/js/index.js
Restart=on-failure
Quick followup release with some fixes.
Plexamp Headless v4.2.2 beta 2
Download here.
Added
  • Browser: Show volume control in tall enough horizontal layouts.
Fixed
  • Browser: Up Next didn’t show up.
  • Browser: Images didn’t work in Firefox.
  • Browser: Signing in using browser.
  • Browser: Don’t show “this device” as a player option.
  • Headless: Don’t run recommended track picker.
Plexamp Headless v4.2.2 beta 3
Download here
Fixed
  • Headless: Don’t download player artwork unnecessarily.
  • Browser: Firebox related tab in player didn’t load.
  • Greatly reduce network calls between playing tracks.
Plexamp Headless v4.2.2 beta 5
(Yes, we skipped one)
Download here
Fixed
  • Headless: Release audio device after being idle for 10 seconds.
Plexamp Headless v4.2.2 beta 7
Download here
Fixed
  • Headless: Distortion with equalizer.
  • Headless: Don’t disable limiter, it works now.
  • Headless: Default caching to only next track.
Closing this as we’re now out of beta, released with other platforms!
Pinning this (again) until we have better installation.
