PlexAmp hijacking Android media volume
PlexAmp 4.3.0, Android 12
Opening PlexAmp on Android is forcibly setting Android media volume to 100% when re-connecting to a remote instance. This is unexpected and unwanted. It came as quite a shock when listening to local radio on another app with handset volume around 30% then opening PlexAmp to ponder what to play remotely afterward.
Is it possible to decouple PlexAmp volume from handset media volume?
I would very much prefer to leave all PlexAmp instances set to 100% and adjust media volume on the handset as and when required.
I suspect this was introduced in 4.3.0 by one or more of the following changes from Plexamp Release Notes - #46 by elan
I have not enabled this setting.
Logs available if required.
Yeah, I can see that being jarring in some cases. It’s the only way to allow the hardware volume to control remote session volume, but I can see where that should probably be an optional feature. Works for some people, doesn’t for others.
Make sense?
Optional feature sounds good. I can definitely understand it being desirable for others.
