PlexAmp Library stuck on CarPlay from (A - K)
Server Version#: 1.22.3.4392
Player Version#: 3.4.4
When trying to check the library on carplay I can only see from A to K, it is stuck
That is your car limiting your lists to a particular length because you’re driving (usually). It’s a rather infuriating limitation, which we can do nothing about.
While that is an infuriating limitation, I’m just happy to see an explanation. Took me a while to hit on the right search terms to find something.
Ah yes, I can imagine!
