Plex amp/ Carplay only seeing half my library in car remotely
Server Version#:latest
Player Version#:latest
I have plex amp in my car, and on my phone. In the car i access it thru Apple Car play. When I search my library, which is roughly 56gb, I can only access artists A-k or @26gb. When I’m home on wifi, sonos, etc and open up plex amp on the phone (on wifi) I see everything. I have not tried to access it thru bluetooth using the app itself bypassing Carplay ( will do today, in edit) - I have a 2019 Jeep Cherokee- its just nice using Car play having directions/music sources/plexamp/Xm/radio all in one spot. Any ideas on what it might be? Car Play is not an app on that model Jeep- I have to plug my phone in to the usb port in the car which brings up car play. Other than that it works flawlessly.
Edit One: Plexamp the apple app used over bluetooth works fine, sees entire library.
The issue has to be carplay- or the Jeep. storage internally if it uses it? Anyone know or have issues with accessing server music library @56gb over carplay connected via usb to open carplay ?? its frustrating.
thank for any help.
This is a CarPlay limitation, the length of lists is limited, usually when driving.
thanks
