Plexamp missing albums (mobile and desktop versions)
I’ve been having this long-standing issue with Plexamp on both the desktop and mobile versions.
If I look at some artists like Joe Satriani on the Plex Desktop app, all his albums show up all the way to his 1986 debut album, but on the Plexamp Desktop app, the list stops at the year 2000, and on the mobile version it stops at 1989.
If I use the search feature in Plexamp, the missing albums can be found and I can play them that way, but I shouldn’t need to search. They should just show up like they do on Plex Desktop.
Is there a known fix for this, or is this a bug being worked on?
Tap on the “Albums” header, if you see a “>” to the right of it, at the window border.
It indicates that there are more items available, than are shown on the Artist screen.
That’s a workaround I suppose, but doesn’t help me if I’m unaware that the albums aren’t all being displayed in the first place. My dad or other friends wouldn’t be aware for sure.
The “>” mentioned above is the indication, that there are more items.
