Plexamp new window controls
THANK YOU!
OK OK but please don’t click the (x) button.
I just used the (x) button
 it displays a popup
 “Are you sure you want to suffer in silence?” haha, just kidding. Thanks for this change as I use the Windows client.
Which version of Plexamp is this in? About shows 4.9.4 but not visible here on Win10 X64.
It needs to be activated in the Plexamp settings first.
Settings → Experience → Desktop Integration → Use System Window Controls
Default is ‘Off’
Requires restarting of PlexAmp to take effect.
With the initial release the window bar looked like this:
As of 4.9.5 it’s using system colors. Is there any way to change it back?
No big deal but I thought it was a weird change.
