Plexamp 4.7.0 no visible UI
Upgraded from 4.6.2 and it opens a window but it stays grey, UI is not updated, no interesting logs except this gpu_memory_buffer_support_x11
I’m on debian 11, I launch it with Plexamp-4.7.0.AppImage --no-sandbox %U
❯ ./Plexamp-4.7.0.AppImage --no-sandbox %U
Main: Window state x:1920 y:42 w:1920 h:2076 fullscreen:undefined maximized:false
Main: Display bounds x:0 y:0 w:3840 h:2160
Started Media Service: false
[723523:0503/124522.284047:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
Linux: Registering MPRIS service.
related systemd logs if needed:
ay  3 12:46:43 booblin dbus-daemon[2993]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.2918' (uid=1000 pid=726288 comm="/tmp/.mount_Plexam2GplEI/plexamp --no-sandbox --en")
May  3 12:46:43 booblin systemd[1]: Condition check resulted in Bluetooth service being skipped.
May  3 12:46:57 booblin systemd[1]: tmp-.mount_Plexam2GplEI.mount: Succeeded.
May  3 12:46:57 booblin systemd[5157]: tmp-.mount_Plexam2GplEI.mount: Succeeded.
I’m using nvidia proprietary drivers by the way
I tried on my laptop that is running bookworm and it starts fine, no gpu_memory_buffer_support_x11 but it has no gpu which might explain it :slight_smile:
the mpris bug is still present though, I updated it in Plexamp mpris bug - #6 by euri10
I’m on Mint 19 and am seeing the same behavior, although my logs have an error message:
➜  app_images ./Plexamp-4.7.0.AppImage --no-sandbox
Main: Window state x:1038 y:1708 w:773 h:582 fullscreen:undefined maximized:false
Main: Display bounds x:640 y:1440 w:1920 h:1080
[143459:0503/084856.295908:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
[143459:0503/084856.296080:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
... Many other similar lines removed for ease of read
[143459:0503/084856.303368:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
[143459:0503/084856.303456:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
[143459:0503/084856.303543:ERROR:gbm_wrapper.cc(292)] Failed to export buffer to dma_buf: No such file or directory (2)
Checking for update
Update for version 4.7.0 is not available (latest version: 4.7.0, downgrade is disallowed).
checkForUpdatesAndNotify called, downloadPromise is null
I have the same problem - Debian, in an environment that has no GPU to speak of (pure framebuffer). All the 4.6 versions work fine. I’ve hacked it right now to not auto update by adding this to my /etc/hosts:
127.0.0.1 plexamp.plex.tv
That makes the update fail, and I can continue using it to play music.
Log of 4.7.0, in a clean environment (no existing Plexamp .cache or .config entries):
user@host:~/Downloads$ ./Plexamp-4.7.0.AppImage
Main: Window state x:undefined y:undefined w:270 h:515 fullscreen:undefined maximized:undefined
Main: Display bounds x:undefined y:undefined w:undefined h:undefined
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[8687:0503/131708.517168:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[8721:0503/131708.751345:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[8740:0503/131708.852808:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
Checking for update
Generated new staging user ID: a5afc551-d4cb-54b5-8de7-cb2001e3e029
I’ve tried variations of -no-sandbox or --no-sandbox and there’s no change. I’ve tried a few various “Disable GPU” incantations and they don’t have any impact either. So, as of right now, 4.7.0 is unusable and I have to prevent the 4.6 auto-update from running to keep my music flowing.
Hi all, this was an interesting one to solve, but we got there. Latest release should fix this. The AppImage is out now, and flatpak is imminent. Thanks for your patience!
Excellent! I just pulled down 4.7.2 and it’s working in the same environment (no GPU, framebuffer only) that 4.7.0 failed in, and I’m happily listening to music again! Thank you very much! Might you be willing to share what the issue was, in case other people run into the problem with their Linux apps?
And there are dozens of us! Dozens! :slight_smile:
The same problem persists in Plexamp 4.7.1 on iOS 16.5.
Everything was ok, the suddenly, blank screen. Doesn’t seem wedged. More like it’s not rendering properly. Only way to remedy is to reinstall and then some non deterministic time later, it goes blank box again.
Linux user #8
Definitely not the same issue, just the same symptom. We’re looking into it, though.
yeah many thanks !
