Thanks, I’ll look into that.
I read this too late, and I didn’t register what it meant.
Since what PA version has it been running on 32-bit raspbian?
I probably said it’s 64-bit a few times.
4.5.1 is working nicely though, except
DJ Snoofer is playing hard to get. ![]()
I think 4.5? Or maybe earlier.
If you want to turn it on and let it run on the Pi, you’ll need to connect via the browser for now. Otherwise if you want a controller Plexamp to drive, that works fine too.
what’s the download link for x86 ?
looking to install plexamp headless on docker on a recuperated mac-mini (10 years old).
Any hints in terms of requirements etc are most welcome.
It’s a single universal download for ARM7, ARM64 and 64-bit Intel. There is no i386 release.
great thanks !
(back on project after holiday stress ![]()
new question: does anybody have or know about a docker image that can be used adapted ? the ones i found so far are very strict tied to a historic version of plexamp and/or rasperry pi.
(will learn how to make docker images if need be but if somebody already has something …)
