Plexamp portable version?
Again i ask as a sugestion, is it possible a plexamp portable version?
There are IOS and Android Plexamp apps if that’s what you’re asking. I use the Android app all the time.
I mean a windows portable.
Mind if I ask what your use-case is? What’s the benefit of a portable build for you?
The purpose of portable apps is so you can run it off a USB stick so you can use it on any computer
To use it at work, as i cannot install programs, per example.
I would think that if your IT department is concerned about you installing programs on your computer, they would most certainly not be in favor of you using a USB stick in any fashion! USB sticks are known security risks.
i can download it from my synology, and usb sticks are not a problem. I have several software i find useful for my work that are not approved but i use the portable version, almost every app as one.
