Plexamp Preferences file format
https://www.reddit.com/r/plexamp/comments/g8ai4l/rplexamp_lounge/k1ac0j4/
I need to manually specify my reverse proxy plex server hostname since my company is blocking the plex discovery service.
I am able to authenticate but then the music library discovery fails. Is there any way I can configure the preferences file manually?
Also is there any way to add a CA certificate that wont get deleted every time plex updates the CA chain?
Should be a server setting to publish a custom URL
Thanks, I had a problem with my reverse proxy config in apache. Once I fixed that along with the custom URL setting, plexamp was happy
Fixing my config using this 2021 post as a guide worked.
It would be great if plexamp honored the windows certificate store rather than bringing it’s own along. I know the app is built to be cross-platform probably to make your lives easier maintenance-wise
