Plexamp repeat doesn’t work for longer playlists/queues
Hello, I’ve seen this exact same question I’m about to ask was raised by someone else in June 2022 but I couldn’t see a reply to the thread, apologies if it’s been answered before elsewhere.
Why if I have a playlist of 25+ songs on repeat all will it not go back to the beginning after the last song finishes? It seems like something obvious Plexamp should do, like all other media players. Or is repeat all only for albums?
Is there a way to change this in future or will it always be like this?
It should work fine, can you be a bit more specific (casting vs not), and post Plexamp logs when it fails?
Thanks for the reply, glad to know it should work.
Not casting, this is when playing a playlist on my phone that I’ve created on my phone (Android). I noticed it when listening to a 49 song playlist, when it gets to the end it then jumps to either the 19th or 29th song and continues. I created a new playlist yesterday with just over 20 songs and when it ended it then went to the ~third song.
I’ve just played the last song of a 49 song playlist and then it’s gone to the 29th song, then I did the plexamp logs. Thanks for your help.
140990106877963.zip (621.4 KB)
Should be fixed in the next release.
Amazing, thank you
