Plexamp Single Item Queue
Just wanted to point out if you start a playback on just a single track (for example a single), even with repeat all enabled, once it finishes the player closes. Repeat single works as expected though. So that has me thinking it’s a function issue with the queue manager, but what do I know. :woman_shrugging: Thank y’all for the constant updates!
What do you expect should happen instead?
If there is nothing selected to play afterwards, why would the player remain open?
Or does Plexamp as a whole close, and not just the “player” overlay of Plexamp?
It sounds like playback stops. Can you reproduce, @OttoKerner ?
I’m not sure what to reproduce. My plexamp as an app remains open if a one-item play queue ends.
The player overlay closes, as expected.
I think this is the key :sweat_smile:
Ahh, I got it.
Yes, player overlay closes after playing the track once. (Windows + Android)
But only if you start a playback and had Repeat All activated already before. If you activate it fresh while the track is playing, it will repeat as expected.
Sorry, I just got in to work to be able to respond. Yes, I meant specifically the current player sheet. I usually have had albums played with repeat all on so when I’ve clicked on single tracks with the repeat all enabled it closed the now playing overlay.
