PlexAmp Tidal Integration Direct Link Sharing
Loving the Tidal integration with PlexAmp. 1 missing thing is the ability to share Tidal links. Currently when you tap share on a Tidal track you can share the image or write to an NFC tag, but no option for the direct Tidal link.
Would it be possible to have an option to do something with the Tidal link? Ideally with options to copy link or use the iOS/Android share sheets to send it to someone.
Would like to remove the Tidal app and go full PlexAmp. But currently can’t send song suggestions to friends without it!
