Plexamp + Tidal library
Just a quick question. On Plexamp do I need to keep switching my source for my own music library and then back to source again tidal every time I want to use tidal?
Many thanks
You can use the Search tab if you want to avoid switching sources.
If you navigate to an artist within your own music library, you will see Tidal’s offerings listed at the bottom.
Bless you, thank you so much for the advice!
also Recent Plays spans sources.
