Is there any way to get to My Tidal stuff in Plexamp? Like my favorited playlists, albums, artists? If not is it possible to add?
Should be on the library tab when TIDAL source is selected.
Completely missed Tidal as a source. I thought it would show up when my library was the source since other Tidal results show there in search. Thanks.
You can select Add to Library and it will ‘merge’ the tidal album with you local collection.
