Plexamp v4.9 removed Library / Soundtracks
Plexamp v4.9 updated overnight on my android device and Library / Soundtracks appears to have been removed.
Is this intentional ?
Plexamp doesn’t remove libraries.
It will only show one library at a time. Which one that is can be selected in its settings section (or by tapping on the server name in the upper left corner of the home page).
Or are you not referring to a library?
Yes, under the library tab on the plexamp app. It used to have Soundtracks as a section, its gone.
I have asked about that.
Though I am wondering why there should be such a section at all. Soundtrack is just an album Genre. You should be easily able to build a smart collection and pin it to the home page, if you are particularly fond of soundtracks.
Thanks.
Yes. Same can be said for Compilations and it has a section.
Anyhow, was asking if it’s removal is intentional or a bug.
Fixed in the next release.
